"Nothing says 1960s more than a strip speedo, something all the rage at the start of that decade.
Chris Cowin takes a look at some cars associated with BMC and British Leyland which featured a strip speedo, an item that clung on in some corners of the product range for far longer than you might think."
https://www.aronline.co.uk/opinion/the- ... edo-years/
The strip speedo years
- mab01uk
- Costafortune
Re: The strip speedo years
I rescued a 1968 Austin 1100 2 door with the daft Mini speedo in the square nacelle - I spent an afternoon converting it to the proper 1100 dash and strip speedo.
Sad or what?
Sad or what?
I am trying to do something with the speedo cable arrangement on my Elf. I have bought an “1100 upper cable” but can’t find any means of connecting to a “lower cable” it there a part to go between the two? My upper is just a plain outer at the bottom end, with a squared end on the inner.
