Lucas WFT576 securing nut
Rev 1.1 (27.07.15)
coopertim
Post by coopertim »
Looking for a Lucas 576 rear facing lamp securing nut which secures the lamp to the inside of the boot. It looks to be 10-12mm but obviously it’s an imperial size and a fine thread. Any ideas / anyone got anything?
Thanks Tim
Morris Cooper ‘S’ 1071 YVH 850
Location: Sunning myself on my top secret tropical island.
Re: Lucas WFT576 securing nut
It's a Cycle Thread. Lucas used them on all their lamps.
Taps are readily available on ebay.
https://www.ebay.co.uk/sch/i.html?_nkw= ... 0&_fosrp=1
All you need to know is the width of the stud in question.
Forum founder, backer & only admin for nearly 20 years.
I Must be f*&%^g mad
coopertim
Post by coopertim »
Cheers Mark! Forum to the rescue again!
Beatie
Post by Beatie »
I should have one or two somewhere which I made up a year or so ago in stainless , will find them out and let you know
coopertim
Post by coopertim »
Cheers Jeremy! Many thanks.
iain1967s
Post by iain1967s »
Beatie
Post by Beatie »
Found them
Mine are 7/16 brass / gas thread which are 26tpi , only difference to to cycle thread is 5 degree different on thread form .
They screw perfect on my Lucas spottys .
They are made from M10 stainless nut re-drilled and tapped out .
Do you need just the one ?
