mk1-forum.net
It is currently Mon May 27, 2019 1:09 am
Post new topic Reply to topic  [ 15 posts ]  Go to page 1, 2  Next
Author Message
PostPosted: Sun Mar 17, 2019 12:58 pm
Offline
Just sorting through some of what I’ve collected and noticed that I have a pair with 21 splines which also appear to be approx .080” smaller in dia than the std 23 spline ones that fit my diff .
Everything else about them looks to be the same .
Anyone know what these are for ?
Jeremy
Top
 Profile
PostPosted: Sun Mar 17, 2019 2:26 pm
Offline
Small update which might help ?
The splines are the same as a rubber coupling output but they would still need the 420 style of cover .
Top
 Profile
PostPosted: Sun Mar 17, 2019 5:12 pm
Offline
They sound like flanges from the late hardy spicer autos.
They fit to pot joint output shafts in the same fashion as a pot joint. You still need S side plate bushes.
If you're thinking of selling let me know as I run these output flanges and one of mine is a bit pitted and leaking slightly.
Iain
Top
 Profile
PostPosted: Sun Mar 17, 2019 8:13 pm
Offline
I'd be interested in these as well if your selling.
Jerry
Top
 Profile
PostPosted: Sun Mar 17, 2019 10:27 pm
Offline
Thanks Iain that makes sense
Are these also referred to as knock ons ?
Yes they will be for sale but only after I inspect them at work next week .
They look to be in great condition and I’ve spun them up on a battery drill with scotch but I would like to mic up the Bush dia as it looks amazingly to good and I wonder whether it’s been skimmed ?
Iain has first dibs for £50.00 if they are not undersize , I would hope to get more on fleabay so have applied forum discount :lol:
Will keep you posted
Top
 Profile
PostPosted: Sun Mar 17, 2019 11:16 pm
Offline
Thanks Jeremy, they look in great condition, much better than mine, I'll have them if they measure up ok.
They probably are known as knock ons as they just thump on over the circlip as per a pot joint. I use the pot joint removal tool to pop them off again.
Iain
Top
 Profile
PostPosted: Mon Mar 18, 2019 10:00 pm
Offline
Have measured around them tonight Iain and they look spot on .
4 tenths of a thou under 1 3/8 and dead parallel :D .
You might want to replace the studs as some have flats on them , ive got a 5/16 die somewhere ( must be at work ) as I could not find it at home yesterday so will see what they clean up like .
Will sort payment and despatch with you after ive found the die
Jeremy
Top
 Profile
PostPosted: Mon Mar 18, 2019 10:02 pm
Offline
Jerry
Sorry Jerry I guess you gathered they have gone .
If your really stuck for a pair then it might be worth contacting Iain as he might have a spare set now but obviously only he can answer .
Many thanks
Jeremy
Top
 Profile
PostPosted: Tue Mar 19, 2019 12:34 am
Offline
Hi Jeremy,
Thanks for the update.
Hi Iain,
Would you be interested in selling your old pair?
Jerry
Top
 Profile
PostPosted: Tue Mar 19, 2019 4:29 am
Offline
Is the hole closed in/covered on the outer end.....Like inside a pot joint?????
Top
 Profile
Who is online
Users browsing this forum: Tim, Time Bandit, timmy201 and 26 guests
Search for:
Jump to:
