Morris FIA Race Car
phil82
Re: Morris FIA Race Car
Post by phil82 »
Etienne, did you have a good night?!
No it's not a Lucas, it's a Tecalemit, but as far as I know they have some problems setting up the injection system.
If anybody has some information on how to tune that and would like to share them, that would be great. I would like to forward them to Juergen who did the rebuild of that car/engine.
alexdenevers
Post by alexdenevers »
Very interesting view of the engine management, especially pulse pump.
The engine doesn't suffered from overheating ? (fan blade..)
The setup above is "TJ" Tacalemit Jackson, lots of details on the main MK1 site.
http://mk1-performance-conversions.co.u ... l_carb.htm
About 1/2 way down.
graham.codling
Post by graham.codling »
assuming fuel pumps are in good running order switch pumps on see how much fuel is going into inake manifold pulling throttle bodies open not by the metering unit adjust pressure regulator to get a drip of fuel every second nip up locnut on regulator set pressure relief valve at around at about 15 pounds set metering cable so min of play be careful not to flood engine hope this helps regards graham
mehariman1
Post by mehariman1 »
Some news...
Image[/quote]
Image[/quote]
Image[/quote]
Image[/quote]
Image[/quote]
mastic
Image[/font][/color]
JC T ONE
Post by JC T ONE »
Looking good 8-)
Pete
Has thanked: 21 times
Been thanked: 49 times
Post by Pete »
I wouldn't have used unvented 'oversills' though , they just fill up with water and rot out. Amazing how many do still use them
mehariman1
Surf 1275 wrote:I wouldn't have used unvented 'oversills' though , they just fill up with water and rot out. Amazing how many do still use them
I totally agree whith you. An other people say me the same.
But it's a race car, so I would like to fix the roll cage to the floor and the bottom box for the rigidity.
Pete
Post by Pete »
Fair comment. :)
By the way talking of sills the worst case I saw of premature rot was on a really nice car that had been sandblasted and the sill sections were left filled to the top with (wet) grit. The new sills took less than three years to rot through. :shock:
JC T ONE
Post by JC T ONE »
No problemo, just drill a 8 mm hole, in bottom of each of the squares.
then water can get out, and more important, you can spray some thin penetrating rust preventing oil inthere 8-) and use one of these long "thingies" with a "shower" effect ;)
YMJ
Post by YMJ »
Surf 1275 wrote: and use one of these long "thingies" with a "shower" effect ;)
[/quote][/quote]
Finnegan's Waxoyl.....ah, :D the 70s
mehariman1
Thanks, JC T one, I go to do hole, and wax.
Today, I finished the roll cage and modified the doors
JC T ONE
Post by JC T ONE »
Nice way to make room for the rollcage 8-) & looks like a very good & safe cage you are doing there 8-)
guru_1071
Post by guru_1071 »
has that cage got its fia paperwork?
mehariman1
Yes I have FIA papers. It is an OMP cage.
Red Mist
Post by Red Mist »
Odd looking cage :?
Have you tried fitting a bucket seat in yet? Looks like it could be a tight fit against the shoulder of the seat.
Neil
mehariman1
It's the same in my inno orange. I just have this picture
Image[/quote]
Red Mist
Post by Red Mist »
Looks snug!
Neil
mehariman1
Rolling train
mehariman1
