Sump guard
General Chat with an emphasis on BMC Minis & Other iconic cars of the 1960's. Includes information on MK1 Action days.
Dr S
Sump guard
Post by Dr S »
Been in stock for Redshed for some time... anyone know what it is, and more criticallly how it fits at the rear. Is it missing a rear mount?
AndyPen
Re: Sump guard
Post by AndyPen »
Is it definitely a mini one? I am trying to imagine it fitted to the front subframe and struggling to see how those 3 bolts would work?
winabbey
Re: Sump guard
Post by winabbey »
Looks like a Mini one to me although I don't know the maker. The three bolts would attach to the leading edge of the subframe with a pair of bolts each side attaching to the side of the subframe, along the lines of this BMC Australia accessory sump guard. The hole in the plate is to enable access to the oil drain plug in the sump.
Dr S
Re: Sump guard
Post by Dr S »
AndyPen wrote:Is it definitely a mini one? I am trying to imagine it fitted to the front subframe and struggling to see how those 3 bolts would work?
The bolts split the sump guard and it kind of wraps around the front rail. Once it’s in place then the drain. plug is in the right space so I think it’s mini...
AndyPen
Re: Sump guard
Post by AndyPen »
Ah that makes sense, and it does look as if it could take an extension if required, but probably not essential.
My old Scottish one used what were effectively the rear sublime exhaust mounts by the way, so you may find some easy solutions.
breklynn
Re: Sump guard
Post by breklynn »
AndyPen wrote: Ah that makes sense, and it does look as if it could take an extension if required, but probably not essential.
My old Scottish one used what were effectively the rear sublime sky bet promo code existing customers mounts by the way, so you may find some easy solutions.
Thanks for the clarification!
Dr S
Re: Sump guard
Post by Dr S »
The mystery deepens -- see here
viewtopic.php?f=28&t=17247
Dr S
Re: Sump guard
Post by Dr S »
We have a part number 18-G 8196 but no one knows what it means...
