mk1-forum.net
It is currently Thu Sep 19, 2019 3:04 am
Post new topic Reply to topic  [ 10 posts ]
Author Message
PostPosted: Fri Mar 16, 2018 6:33 pm
Offline
Just been under the mini and noticed the handbrake cables are touching the body and have already rubbed through the paint (only been on a couple of months and only put handbrake on and off a few times to adjust the brakes)
Anyone else come across this or have i done something wrong?
Top
 Profile
PostPosted: Fri Mar 16, 2018 6:52 pm
Offline
I know that it's a palliative and not a cure as such but couldn't you attach a hard nylon 'rubbing strip' to cure it. There's enough thread on the retaining bolts to add and secure a nylon whatsit piece that would run UNDER the cable
Top
 Profile
PostPosted: Fri Mar 16, 2018 6:59 pm
Offline
I think this issue is normal .. it is just the same on my twin cable handbrake cars.. i just stick some silicone grease on the area.
Top
 Profile
PostPosted: Fri Mar 16, 2018 9:55 pm
Offline
Thanks chaps. That was going to be the solution Peter as long as I hadn't done anything wrong, which going off what polar says it seems I haven't
Top
 Profile
PostPosted: Sat Mar 17, 2018 9:17 pm
Offline
peter just what i did,
used a short length of fuel hose (about 3-4 cm long), slit if down its length on one side and clipped it over the cable, works fine, you could also smear a bit of grease in the hose to help it slide.
Dean
Top
 Profile
PostPosted: Sat Mar 17, 2018 10:07 pm
Offline
Good idea. The trouble with that as I can see it is that the hose will probably/might slide rearwards and you'll be back to square one. Once it's slipped rearwards under constant tightening and releasing it won't be able to slip forwards between the cable and body. Maybe not but worth keeping an eye on. I'll be checking mine tomorrow now and do something similar but will anchor the hose somehow.
Top
 Profile
PostPosted: Sat Mar 17, 2018 10:52 pm
Offline
This is a picture of the underneath my 62 Riley Elf..Original car. They had two pieces of tar type padding fitted.
Top
 Profile
PostPosted: Mon Apr 16, 2018 10:19 pm
Offline
Just following this up for anyone suffering from the same condition, this is how I sorted it. A piece of 3mm nylon plate to keep it off the floor. Not sure it will last long before it wears through so will keep an eye on it
Top
 Profile
PostPosted: Tue Apr 17, 2018 8:58 am
Offline
GREAT idea Callum. That's my next job, this weekend when it's off the floor having the slave laid-up-for-the winter wheels/tyres replaced. Maybe someone with an hour or two on his hands to spare ought to gather together all the threads linked to HANDBRAKE CABLE TROUBLES and put them all into one easily get-to wotsit for computer thicko's like me to access at the push of a button
Last edited by Peter Laidler on Tue Apr 17, 2018 10:22 am, edited 1 time in total.
Top
 Profile
PostPosted: Tue Apr 17, 2018 9:08 am
Offline
Nice solution Callum.
_________________
Forum founder, backer & only admin for nearly 20 years.
I Must be f*&%^g mad
Top
 Profile
Who is online
Users browsing this forum: johnv and 15 guests
Search for:
Jump to:
Localized by MaĆ«l Soucaze © 2010 phpBB.fr
