mk1-forum.net
It is currently Sat Feb 23, 2019 9:32 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2, 3
Author Message
PostPosted: Sun Dec 03, 2017 1:31 pm
Offline
I would also not expect a difference between auto and manual when the same type of joint is concerned. However, auto's have hardy spicer joints and all other have rubber joints until somewhere in 1973 when pots where introduced for auto and manual (probably around the same time it happened for the Mini.
I edited my previous post for a suggestion on how to get a set of pot joint shafts: the pot joint inner bit does not fit to an earlier shaft as the splines are different.
I do expect that pot joints shafts are longer than rubber or hardy spicer shafts as the pivot point for pot joints is just before the end of the shaft while for the other types is beyond the length of the shaft (at the center of the rubber or hardy spicer joint).
_________________
1964 Austin Cooper S 1275
1965 Volvo Amazon Combi
1965 Austin Cooper 998
1967 Morris Minor 1000
1967 Austin Cooper 998 Mk II
1969 Austin Cooper S 1275
1972 Austin 1300GT (2x)
1975 Mini Jubilee
1978 Mini 1000
Top
 Profile
PostPosted: Tue Dec 05, 2017 12:38 pm
Offline
If you cannot get a set of Mk3 shafts, Metro long and mini long shaft is what you want I believe.
There is a caveat. I have not yet fitted this setup into a car to definitively confirm that this works. I took a punt buying some metro shafts from the UK to Aus based on someone posting that a long mini and a long metro shaft had been used successfully. I had tried to get a hold of some Mk3 shafts with no luck.
I took a pair of mini rubber uni shafts and compared their length to mini pot joint shafts. The extra length of the pot shafts is the important dimension so you want shafts that are longer then the 1100 rubber uni shafts by the same amount. I then took the short 1100 rubber uni shaft and compared it to a mini long pot shaft and a metro long pot shaft to the 1100 long rubber uni shaft. The difference in length is essentially the same as with mini rubber uni and pot shafts.
If Rich can get an actual set of Mk3 shafts remade, I would be keen on a pair!
cheers
Kevin
Top
 Profile
PostPosted: Tue Dec 05, 2017 12:46 pm
Offline
i now have in my possession 2 x nos 22G2093 shafts (the RH one), so all I need is a known LH on
I'm still looking!
_________________
'long beard boss'
Top
 Profile
PostPosted: Wed Dec 06, 2017 11:56 am
Offline
Hi Rich,
the MG1300 i've bought for spares had pot joint shafts.
They are still there, i can take the left one out and will let you know.
I also have a NOS pot joint shaft ( no part number ) wrapped in paper and hand written "Austin 1300"....
i will remove the left one from the car ( no engine ) and compare both.
will be able to do it only next Weekend.
Luis
Top
 Profile
PostPosted: Fri Dec 08, 2017 2:55 pm
Offline
Looks like Luis could be your man Rich! :)
I sent you an email with the number of Shaun who also thinks he might be able to help.
_________________
David - chairman@ado16.info
1968 MG 1300 Saloon Connaught Green
1972 Triumph 2.5 PI Estate Royal Blue
1978 Carlight Casetta Caravan
http://carlightrestoration.blogspot.co.uk
1995 Lada Riva 1.5 Estate Cherry
Top
 Profile
PostPosted: Sat Dec 09, 2017 8:33 pm
Offline
Hi Rich,
ok i took the LH pot joint shaft from my 1970 MG1300, i do not know how it got pot joing shafts and rod change gearbox!
it is NOT the same length as the mini long ( RH ) shaft , as we all suspected. It is ~8,5mm shorter .
In the pictures from top to bottom:
Used Long RH Metro shaft
NOS Shaft wrongly wrapped in paper saying "Austin 1300", it is same length as a RH mini one
Used MG1300 shaft, ~8,5mm shorter than the RH long mini one. Note it has an additional ring embossed.. the RH shaft ( kept it in the car ) has the same ring.
Used RH Mini shaft
Used LH mini short shaft
I'm happy to loan you the shaft Rich.
Luis
Top
 Profile
PostPosted: Sat Dec 09, 2017 9:36 pm
Offline
interesting
I will have to have a look at the nos allegro one (same as a 1300, or so the part number says!) to see if it has the second ring
might be an easy way to tell them apart from the others
good sleuthing luis!
_________________
'long beard boss'
Top
 Profile
PostPosted: Mon Dec 11, 2017 1:21 pm
Offline
ive had a look and the 22G2093 and it also has the very feint second ring machined into it.
_________________
'long beard boss'
Top
 Profile
Who is online
Users browsing this forum: 111Robin and 3 guests
Search for:
Jump to:
