mk1-forum.net
It is currently Sat Feb 16, 2019 9:18 am
Post new topic Reply to topic  [ 83 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 9  Next
Author Message
PostPosted: Wed Aug 09, 2017 6:52 am
Offline
Very useful information thanks. I had dealings with many seal suppliers at work previously so might give them a call. I'm sure if I sent the seals to them they could find some current alternatives. Likely to be pricey though.
Top
 Profile
PostPosted: Wed Aug 09, 2017 9:08 am
Offline
I bought a knackered hydro pump off ebay a few years ago, stripped it & decided I couldn't decide how to make it work, with the info above, I am now filled with hope (again).
Thanks folks.
_________________
Top
 Profile
PostPosted: Wed Aug 09, 2017 10:09 am
Offline
The garage i worked in as a lad had a pump, but it wasnt like one i had seen before
My boss had worked for a Austin dealer in the 60's and had acquired it from there
I t looked just like a grease gun but was a hydro pump, he told me it was a portable one that was much handier to take to broken down vehicles, he still has it i will try to get a pic the next time i see him
_________________
http://www.dunsdalecoachworks.com
Top
 Profile
PostPosted: Wed Aug 09, 2017 10:27 am
Offline
Thanks for that information Winabby. Extremely useful.
Top
 Profile
PostPosted: Wed Aug 09, 2017 10:53 am
Offline
you can convert a normal grease gun if you put the right fitting on the end
they are pretty slow to use and it would be a pain to re-fill a full system, but they work ok for quick little adjustments.
a mate of mine used to have one and I used it a few times
_________________
'long beard boss'
Top
 Profile
PostPosted: Wed Aug 09, 2017 11:17 am
Offline
I have the innocenti model pump..
The vacuum pump works little, the pump has the pin irremediably damaged.
However, you can do the same to charge the units, take some time and a little liquid is lost.
The mechanism is the same:
Image20160302_141950
Image20160302_141944
Image20160302_144804
Image20160302_141939
Image20160302_141956
Top
 Profile
PostPosted: Wed Aug 09, 2017 11:35 am
Offline
it probably does cappuccinos as well! :lol:
_________________
'long beard boss'
Top
 Profile
PostPosted: Wed Aug 09, 2017 12:11 pm
Offline
Winabbey: thanks for posting those, I hadn't been able to find large scale reference like that, it could make the search for parts a bit easier.
Geroch: Never seen an Innocenti one before. Typically it's ever so slightly better looking than the British version.
Top
 Profile
PostPosted: Wed Aug 09, 2017 5:34 pm
Offline
Has anyone got a knackered one that would donate the gauges? I have a borrowed one that needs TLC. Again VAC doesn't work, but I can probably make the parts.
Cheers - Chris.
Top
 Profile
PostPosted: Wed Aug 09, 2017 6:26 pm
Offline
Vulgalour wrote:
If you've got one and it works, look after it. They're quite prized things now. I only wish mine worked, especially since I have both a Hydralastic and a Hydragas car that would benefit from its services. There is someone local with a Liquid Levers pump but that has no vacuum function and it costs to get him to come to the car, which can get a bit expensive if you need multiple call outs.
I have an early liquid levers pump. When it packed up I opened it to see what was wrong to find a cheap plastic bottle for a tank and a clutch slave cylinder for the pump.
There is no vacuum on this model but at least it's easy to fix. :roll:
Top
 Profile
Who is online
Users browsing this forum: rnp68 and 17 guests
Search for:
Jump to:
