MKII Bits wanted
Rev 1.2 (16.09.20)
Rev 1.2 (16.09.20)
MKII Bits wanted
Having said I wasn't buying any more Minis and I was going to thin out the fleet,I've just gone a bought another Mini.This time it's another 1968 CKD Irish MKII Austin 1000 and while scabby it is solid enough that I'm hopeful it does not come back in a bag from the blasters when I send it off
.I'll start a build thread when I start work on it.Anyway its missing a few bits so I said I'll start looking while I being stripping it.I need a steering column,indicator stalk and steering column cowl and I need the surround for a rear Austin Mini MK2 badge and also the 1000 script that goes on the bottom right hand corner of the bootlid.I also need a round Austin bonnet badge and surround.If it makes it easier shipping can be arranged to my sisters house in Surrey .Hopefully someone out there can help.Thanks
Re: MKII Bits wanted
I certainely have rear badges and surround if it can help
- pdb
I believe that I can help you with all the parts from Denmark. The only things I'm not sure of is the steering column cowl. If there is a difference between LHD and RHD cowls, then I am not able to supply that.
Regards, Per
Regards, Per
Aidan , I can help with the rear surround and the 1000 badge . will check the front round one , might have that as well . G
Pretty sure I have an indicator stalk.
