Diff covers
Rev 1.2 (16.09.20)
Aginley
Diff covers
Post by Aginley »
Wanted hardy spicer diff covers to fit a 333 box.
Think they are a different internal diameter for the Hardy’s
iain1967s
Re: Diff covers
Post by iain1967s »
I used the MiniSpares rod change version, and cut the detent lug off with a hacksaw
https://www.minispares.com/product/Classic/22G420.aspx
Rolandino
Re: Diff covers
Post by Rolandino »
Hi, I had the same problem after I found out that one of my covers had a split in it. I bought one of the 22G420 side covers and with a fret saw I cut off the "ear" for the detent on a rod change gearbox. With careful sanding and painting, you cant see the difference. R
kit of bits
Re: Diff covers
Post by kit of bits »
I had HS outputs on my 333 box using 420 side covers..
Re: Diff covers
Just as another option here, some of the side covers for the Rubber Joints had extra meat cast in to them (quite like the same casting as S Plates) and can easily be turned in a lathe to take the S Bush and Seal. I haven't needed these in recent years, but in the 80's I did loads on them.
Re: Diff covers
That's what I have on 9748KO Chris ... 15 years on and never had a problem or leak !
That said, I'd have fitted 420's if I had them at the time ;)
360gts
Re: Diff covers
Post by 360gts »
Andrew1967 wrote: Mon Apr 12, 2021 8:39 pm That's what I have on 9748KO Chris ... 15 years on and never had a problem or leak !
I have turned many of the standard side plates and fitted the larger bush/seal...and as Andrew stated...no issues. Been doing this for years.
It is an inexpensive solution to the 420's ...............and there is an an abundant supply of the standard ones.
