I had the same problem, years ag, all I did was drill the body where the peg was and put in a cut-down split pin in it. worked well, as the rubber grommet should allow the float chamber to "float"
I've repaired a few carbs with the same problem, caused by not holding the float chamber when undoing the bolt. I drilled and tapped them M3 for a s/steel bolt and made a small ally block to suit. If you get stuck I might have a few spares somewhere.
