Wanted square clutch pedal
Rev 1.2 (16.09.20)
floormanager
Post by floormanager »
Looking for a clutch pedal square-type, suitable for a MK2. Happy if the hole is elongated, as I will get it welded up and re-drilled. Just need a clutch pedal.
Thanks,
Paul
floormanager
Re: Wanted square clutch pedal
Any clutch pedals out there want to be in a Cooper S?
Only found brake pedals so far Paul (not S ones).
Will have another look later on.
floormanager
Andrew1967 wrote: Sun Feb 14, 2021 11:37 am Only found brake pedals so far Paul (not S ones).
Thanks Andrew. Need to build up a new clutch pedal as mine is opened up to 10mm!
Paul
Chewie Baker
Post by Chewie Baker »
Can someone clarify if this is brake or clutch?
I'd say that's brake, as I think the long shoulder goes to the inside of the pedal box, up against the same length shoulder on the clutch pedal...if that makes sense :? (might do now after correcting a typo :oops: :lol: )
GraemeC
Post by GraemeC »
I’d agree - the spring sits on the longer tubes, between the pedals.
winabbey
Post by winabbey »
floormanager wrote: Fri Feb 12, 2021 7:35 pm Looking for a clutch pedal square-type, suitable for a MK2. Happy if the hole is elongated, as I will get it welded up and re-drilled. Just need a clutch pedal.
Thanks,
Paul
Is it the clevis pin hole that's elongated?
floormanager
winabbey wrote: Mon Feb 15, 2021 4:30 am
Yes winabbey. Mine has worn, it's been drilled out before and is now accepting a 10mm bolt! I want to swap it out and return the car to standard size. Happy to keep the one in the car until a replacement has been sourced.
Paul
winabbey
Post by winabbey »
OK. I ask because I refurbished my pedals when the holes elongated.
I thought these were the three options:
1. Drill a larger hole in the pedal and master cylinder rod and fit a larger diameter clevis pin.
2. Weld the hole in the pedal, re-drill to original size (5/16") and fit a standard clevis pin.
3. Similar to option 2, but sleeve the hole back to original size.
I went for option 3, but the holes wasn't as big as your 10 mm one. I think I saw the technique on here somewhere, perhaps by Peter Laidler.
Here's the components - an 11/32" drill bit, brass tube from modelling shop and a pair of ball bearings to flare the brass sleeve. Some copper grease to lubricate.
