[Wanted] starter, spring compressor tool
Rev 1.2 (16.09.20)
moita
Post by moita »
Hi,
Does anyone have the "C"s tool that wants to depart with? To compress the spring to allow to rebuild the starter !
Thank you,
Nuno Moita
wild_willy
Re: [Wanted] starter, spring compressor tool
Post by wild_willy »
I use 2 vice gripps to compress the spring. Works ok.
Craig
Post by Craig »
I made a few some years back. Quite simple really , a couple of 1" I'd flat washers .one with a slot cut in it ,drilled and tapped for two 1/4" NF bolts.
I would be happy to send you one for postage cost. .
Will try to resize pics and post here .
Craig
CooperTune
Post by CooperTune »
Crude as it is some where around my press there is a plumbing coupling 1/2 or 3/4 I hack sawed a section from the side ( an opening to work though ) I place the starter on it's end position the open coupling on the retainer and press just enough the remove the clip. As we all know assembly is the reverse. Steve (CTR)
whistler
Post by whistler »
Whichever method you use, make you do the job in a cardboard box or similar as the C ring will likely fly off into the distant future. I lost one 3 years ago and still haven't found it. A bit like the balls and springs from a synchro hub.
My quote of the day :lol:
General dogsbody.
JohnA
Location: Up north where men are men and sheep are frightened
Post by JohnA »
This is an original tool I've had for a long time. The picture should help if anyone wants to make one.
moita
Post by moita »
Thank you all for comments and help.
Now sorted :)
