"MGB induction loop fitting" for Speedwell tacho
Rev 1.2 (16.09.20)
Andrew850
Post by Andrew850 »
Hi there!
Looking for an "MGB induction loop fitting" (such as the one in the pic) to be able to connect my (Smiths type) Speedwell tacho in my '66 Cooper.
regards,
Andrew
850man
Re: "MGB induction loop fitting" for Speedwell tacho
Post by 850man »
That's a std Smiths tacho loop fitting. They were fitted to every smiths Tacho for many years.
I have a heap of them but I am on the other side of the world. I am happy to send you one if you must have one.
Consider having the Tacho converted with modern internals and then all you will require is a single wire, get rid of the loop. And it will work with an electronic ignition system.
johnv
Post by johnv »
Mine works with electronic ignition. I started off with points and then changed to petronix from the distributor doctor and the Rev counter kept on working properly
Mk2 Cooper
Mk1 Cooper project
Mk3 Cooper S
Andrew850
Post by Andrew850 »
850man wrote:
Wed Oct 07, 2020 8:52 am
Many thanks for replying here. I apologise for not getting back earlier but been absent for a few days. Will send you a PM to discuss further. Thanks again. Andrew
phil.1380
Post by phil.1380 »
You can get the parts from here, for example the nylon shoe bit: https://www.ahead4healeys.co.uk/-NYLON- ... 13154.aspx
Just had to get some parts myself from them for an MGB Tach.
Phil.
