Wanted Mk1 S - Crank, Inlet Manifold/Carbs, Remote & SW5
Rev 1.2 (16.09.20)
Fiveposter
Post by Fiveposter »
Wanted Mk1 S - Crank, Inlet Manifold/Carbs, Remote & SW5 Cam - any condition considered (just not really bad).
Cam / remote found - I am still looking for a Mk1 1275 S inlet manifold and crank.
Please contact me if you have either of these - thanks
GraemeC
Re: Wanted Mk1 S - Crank, Inlet Manifold/Carbs, Remote & SW5
Post by GraemeC »
Might have an SW5 - will check
jayare
Post by jayare »
I have a used SW5 - I’ll get some photos on Thursday if you are looking interested (I’m away until then)
JR
Alex
Post by Alex »
By remote do you mean the whole gearbox, the remote housing, or a gearlever ?
I've got a few housings, and maybe a lever.
nick rogers
Post by nick rogers »
I have cranks, carbs and remotes.
nick rogers
Remote vapour blasted, stick re-chromed, then re-assembled.
GraemeC
Post by GraemeC »
The SW5 I thought I had isn't one!
jayare
Post by jayare »
SW5:
First photo is a bit rubbish but it is definitely an SW5! I have some more photos I can email if required. Whilst looking it out, I also found a remote housing and gear-lever and a set of twin HS2's with airbox that will need a full going-over. Let me know if you'd like photos or further details of those too,
JR
Fiveposter
Cam / remote found - I am still looking for a Mk1 275S inlet manifold and crank.
PhilC
Post by PhilC »
Hi
I have set of 1275s carbs linkages etc on an AEG 347 manifold. All in very good condition.
Phil
