Lay shaft for a 333 box
Rev 1.1 (27.07.15)
Aginley
Post by Aginley »
As per title. After a nos lay shaft for a 333 box
CooperTune
Re: Lay shaft for a 333 box
Post by CooperTune »
Not that I have one to offer but what part # are you after? I'm sure there are at least two possible. Steve (CTR)
whistler
Post by whistler »
Have you talked to John Guess about this?
Location: In the Herb Garden (Somewhere in the North of England)
Give Rich at MS a ring Al.
"I'm a very friendly Lion called Parsley".
iain1967s
Post by iain1967s »
I used the Minispares C-22A1731 with their 22G1100 laygear for my 333 build with no issues during assembly.
Just make sure if using the new longer type needle roller bearings that you get the retainer circlips in the right place.
(two fitted to the inner-most grooves, none in the outer grooves)
kit of bits
Post by kit of bits »
I bought one from the eBay chap in Spain £ ouch..
Aginley
Post by Aginley »
Thanks for the replies, think I need the gear too. Only very minor pitting but better safe than sorry while it’s stripped down.
Tedwong
Post by Tedwong »
iain1967s wrote:
Fri Jul 31, 2020 5:25 pm
May I ask is it only 22G1100 laygear need those circlips to retain the bearings? As I just assemble my 3-synchro straight cut laygear and can't recall I used or needed any circlips at all!
Ted
iain1967s
Post by iain1967s »
22G1100 helical laygears from MS etc. have both grooves machined, so either arrangement of long bearing, or short bearing + spacer, can be used. I don't know about other laygears, but there seem to have been two basic styles.
The earlier laygears used an inner circlip, then a spacer, then a short bearing, then an outer circlip to capture the bearing inside the laygear as a complete assembly. Most of the workshop manuals and websites show this arrangement in their assembly diagrams.
The later type used the inner circlip with a longer bearing and no spacer. These longer bearings 'float' against the thrust washers on the outer ends, and do not use the outer circlip. I posted a corrected diagram on this thread: viewtopic.php?p=227859#p227859
Caution: When the laygear with the longer floating type bearings was first introduced, it had no outer circlip groove machined. Those laygear used a slightly different longer bearing type but with narrower cage ends and rollers that extend almost to the end of the cage. Don't use those transitional bearings on a modern laygear which has the outer groove, because the rollers running over that groove can cause premature bearing failure.
[There was a discussion about it previously from someone else on here I think... most of the currently available longer bearing have wider cage ends and slightly shorter rollers, so they don't run into the area of the unused outer circlip groove. It's pretty obvious when you come to assemble whether you have the correct bearing type.]
