Weslake Iron 8 port - Manifold required
Rev 1.1 (27.07.15)
Julian Harber
Post by Julian Harber »
Inlet manifold (throttle bodies) for a Weslake cast iron 8 port head running TJ fuel injection to buy or loan to make pattern to cast new manifold
Julian Harber
Re: Weslake Iron 8 port - Manifold required
Thank you really appreciated however as you reply did not flag up and I hadn't looked with everthing going on the aution had ended but we will try and contact the original seller all the same - if anything else turns up please message me - Kind Regards Julian
trevorhp
Post by trevorhp »
Hi Julian
I think I have 4 different types: 2 x Steel fabricated and 2 x aluminium.
I think I also have a spare alloy one somewhere but it's originally from an Arden head but could easily be modified to fit.
I will try to post some pictures here soon.
FYI I believe that the throttle body spacing is the same as or similar to a Weber DCOE
Trevor
Julian Harber
Trevor this sounds promising I alaways have problems putting photos on our MK1 site so it may be easier to email me
julian@chelt.com
trevorhp
Post by trevorhp »
Will do
Trevor
trevorhp
Post by trevorhp »
Email sent direct
There will be questions I am sure
Fire away
Steel manifolds are mainly home made and I'm sure you are capable of doing that so no point in sending pictures.
KDK and HDK have Vita's special Gp5 extra short Throttle bodies which mount directly to the Weslake Head
Trevor
trevorhp
Post by trevorhp »
Not sure you received email so:...
trevorhp
Post by trevorhp »
850man
Post by 850man »
Contact Simon Young at British Sporting Cars in Australia.
He has had the inlet manifolds and sliding throttle body assemblies re manufactured.
https://www.britishsportingcars.com.au/
