Wanted NERUS rocker cover
Rev 1.1 (27.07.15)
roymck
Post by roymck »
Yes I know it’s a long shot but I am after a NERUS rocker cover .
8662 FN Austin Mini
I know its not original I like it this way
roymck
Re: Wanted NERUS rocker cover
Post by roymck »
Still looking for one of these .
8662 FN Austin Mini
roymck
Post by roymck »
To go with these .
8662 FN Austin Mini
NZmember
Post by NZmember »
What is the tag ID on the carbs?
I have an Alexander conversions set and the carb tags indicate 997 carbs. Just interested in what the Nerus set up has.
Derek
Toby
Post by Toby »
NZmember wrote:
Sun May 24, 2020 5:57 pm
Derek
On mine they have the tags from a 998, so I guess it could be anything.
roymck
Post by roymck »
No Tags , so guess they are just a made up set . Apart from the needles would have thought all early SU carbs are pretty the same . I know the later ones incorporated some kind of engine breather intake.
8662 FN Austin Mini
ricardo
Post by ricardo »
Mine have the same setup as the Speedwell sprint sets. They look original / unmessed with for decades.
NZmember
Post by NZmember »
Apart from Roymck needing a second standard HS2, has anyone cut off the inlet and used the cast iron exhaust manifold rather than a freelow?
I see on the Nerus page they also did a version of the standard rocker cover. Is that an option?
roymck
Post by roymck »
NZmember wrote:
Tue May 26, 2020 5:58 pm
Bit confused , I don’t need a second standard SU , it’s just a Nerus Alloy rocker cover I am looking for .
8662 FN Austin Mini
NZmember
Post by NZmember »
Sorry, there were comments that the original Nerus manifold had two standard SU carbs connected rather than the Cooper style you now have. If you go down the Nerus tuning look you may consider that?
But as I was interested in your Nerus question I saw on the MK1 site they also did another rocker cover you might search for. Just suggesting other options.
