AEG163 Head wanted
Rev 1.1 (27.07.15)
Gary Schulz
AEG163 Head wanted
Post by Gary Schulz »
Also looking for a decent AEG163 head if there is another one kicking around out there. Let me know of any availability and condition etc...
Gary Schulz
Re: AEG163 Head wanted
Anyone?
spoon.450
Post by spoon.450 »
By “ decent “ do you mean un cracked ....
Gary Schulz
spoon.450 wrote:By “ decent “ do you mean un cracked ....
Yes, no cracks. I have been dealing with a cracked one for months now trying to get a satisfactory fix and so far no luck...
timmy201
Post by timmy201 »
Minimania is the only place I’ve seen them, or have you tried them already?
https://www.minimania.com/part/AEG163-R ... nd-Springs
I'm a rather fat feathery Owl called sage.
Gary Schulz
Thanks for the replies. I have been in contact with MiniMania for quite some time and they do not anticipate seeing any of these for a while (if ever).
My luck with eBay on items like these has been running about 50%. I have had a few too many cases where what I got wasn't at all what was described and it wound up costing me a lot of $ for nothing. Not saying that is the case with these two but it's a lot of money to risk...
I had a response to this via PM so hopefully it turns out,
Thanks for any additional leads! My entire restoration has been stalled for many months pretty much because of this one issue.
Pete
Post by Pete »
Pretty sure I can help you out Gary, I need to check the ones I have and will get back to you.
Gary Schulz
Still searching. I think my leads have gone cold...
Just stripped my 2nd 163 and discovered its cracked as well :cry:
It had been repaired at sometime on No1 but cracked again in the same place.
Reckon the 940 will be going back on ....
