Cooper demister dash trim
Rev 1.1 (27.07.15)
coopertim
Post by coopertim »
As above, looking for Cooper demister trim pieces.
Thanks Tim
Morris Cooper ‘S’ 1071 YVH 850
rpb203
Re: Cooper demister dash trim
Post by rpb203 »
Are you after the metal bits that screw over the heater outlet on the dash top?
coopertim
Post by coopertim »
That’s the ones!
Tim
rpb203
Post by rpb203 »
Tim,
Have sent you a pm
Gary
coopertim
Post by coopertim »
Replied
Thanks Tim
360gts
Post by 360gts »
Tim
If you can't locate the demister trim bits in the UK...I have some that are restored and ready to install.
johnv
Post by johnv »
Any known sources for the chrome screws?
Mk2 Cooper
Mk1 project
360gts
Post by 360gts »
johnv wrote:Any known sources for the chrome screws?
Somerford show the chrome machine screw that is used on the earlier steel ducts...later cars with the plastic duct uses a chrome self tapper...these should be available as well. (both are Phillips style)
http://www.somerfordmini.co.uk/eshop/in ... ts_id=2278
coopertim
Post by coopertim »
Now sorted thanks again to this fantastic community!
Tim
