MARK ONE FENDER FLARES
Rev 1.1 (27.07.15)
Jim1071
Post by Jim1071 »
HI
Do you know anybody that sells the aluminuim fender flares that rivet to the side of the car
usually people paint them body cover
thanks
jim biscoe
1964 Austin Cooper S 1071cc
1967 Austin cooper S vintage race car 1293
1978 Austin Mini 1000
1999 Mayfair Rover 1275 spi
timmy201
Re: MARK ONE FENDER FLARES
Post by timmy201 »
They are “Cosmic” wheel arches. I’ve seen some aluminium copies come up every now and then but can’t see any at the moment.
You can get fibreglass copies from here
https://www.absmotorsport.co.uk/product ... heel-arch/
1071 S
Post by 1071 S »
DON'T DO IT..... A PO fitted something similar to mine years ago and I've regretted it ever since. Removal will involve pretty much complete paint job as well as welding smoothing etc.
Cheers, Ian
Jim1071
Post by Jim1071 »
1071 S wrote:DON'T DO IT..... A PO fitted something similar to mine years ago and I've regretted it ever since. Removal will involve pretty much complete paint job as well as welding smoothing etc.
Cheers, Ian
hi Ian
this is on the race car for tire clearance , you are probably right I would not install on my street car
I currently have the aluminum Cosmic fender flares on the car
and one is beet up so I wanted to replace them
thanks
jim
swindrum
Post by swindrum »
Jim, I may have access to a NOS set. They belong to a friend, I can ask if he is using them...
Sean
Workinprogress
Post by Workinprogress »
There is a set for sale right now on kijiji in the maritimes,
https://www.kijiji.ca/v-auto-body-parts ... nFlag=true
Good luck,
Bruce
Jim1071
Post by Jim1071 »
Workinprogress wrote:There is a set for sale right now on kijiji in the maritimes,
Good luck,
Bruce
thanks
I just tried contacting them ... looks like only one Aluminum Flare available
LuisM
Post by LuisM »
Anyone is familiar with an Alloy Arch set made by Grayston , very similar or same as the alloy Cosmic ones?
Are they the same as the Cosmic's , just branded differently ?
Luis
