mk1-forum.net
It is currently Mon Feb 18, 2019 11:06 am
Rev 1.1 (27.07.15)
Post new topic Reply to topic  [ 3 posts ]
Author Message
PostPosted: Wed Sep 19, 2018 10:09 am
Offline
Ideally a NOS rod change set up.
Paul
Top
 Profile
PostPosted: Wed Sep 19, 2018 12:22 pm
Offline
Location: Up north where men are men and sheep are frightened
Which year, long or short?
Top
 Profile
PostPosted: Thu Sep 20, 2018 1:51 pm
Offline
I realize it's to far to help but I have bought the reamers to bore the housings to accept .625 oil-lite bushings then run a .500 reamer through. I also bore the shifting eye and press a 6160 sleeve in place then hone to match the stickball. Also, I press a 1.00X.500x.250 grease seal in the front of the housing. I have found placing a hose clamp around the shifter retaining cup below the pins and tightening it reduces the play at the knob. So far flipping the shaft has worked but I need to order drill rod as some are to far gone on both ends. Steve (CTR)
PS have also machined the shifting eye to accept a spherical bearing which requires removing the ball and polishing the shaft in the ball area. I may have first seen that on this board.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 2 guests
Search for:
Jump to:
Localized by MaĆ«l Soucaze © 2010 phpBB.fr
