Multiple Parts
For Sale Section Rules
1) This section is for advertising items that you have for sale. Not for the discussion of listed items. If you wish to debate the pro's & Con's of any item listed, please start a new topic in the appropriate section.
2) Please DO NOT post links to your ebay auctions. This section is NOT for the advertisement of your ebay auctions.
5) Items listed for sale should WHEREVER POSSIBLE* be offered with a purchase price, not asking for bids from members. If you wish to auction your item to the highest bidder I would suggest you use ebay & pay the associated fees.
6) This section is offered as a free service to enthusiasts. Any deals made are between the buyer & seller only. The MK1 forum takes no part in any transaction & the appearance of any item in this section is not a recommendation. I strongly suggest that both buyers & sellers are happy to proceed with a deal before any money or goods change hands.
7) It expected that people posting items for sale are "Active Members of this community". Any Adverts placed by members with a post count lower than 5 will be deleted.
8) The advertising of or soliciting for VIN tags, log books or any other vehicle identification documentation without it's associated vehicle is expressly forbidden. Any member breaking this rule will have his membership terminated with immediate effect.
9) If a moderator considers any postings in this section to violate either the spirit or word of these simple requests the MK1 Forum reserves the right to delete any posts without prior warning or explanation.
10) The posting of items for sale on the MK1 forum constitutes explicit acceptance of these simple rules.
11) Members posting items for sale MUST include a rough location in their profile.
It would be much appreciated if sellers could leave the sale price on adverts after the item has been sold. This acts as a good measure of current value for other sellers.
* In some cases it may not be possible for the seller to list items with a sale price. In this case, listings will be reviewed on a case by case basis by a moderator. The moderators decision will be final.
Rev 2.10 (06.10.20)
Rev 2.10 (06.10.20)
Multiple Parts
I have the following parts for sale:
1) 1275 pre A+ engine (just stripped) all standard and looks to be in good condition. May go again with rings and a crank polish or a nice basis for a performance build to first over/undersize. Complete with std valve flat top head, flywheel and clutch and Purolator filter. £375 (SOLD)
2) ‘Project head’ – 11 stud head which I started to port in the Des Hammill way. Tracts and throats opened out, guide bosses removed, some work started on chamber shaping. I took hours on this and think I’ve done a decent job – no pushrod break through. Complete with valves and double springs. Needs completing – nice ‘winter nights’ project. £125
3) Tin rocker covers – 1 with angle breather £20. One with vertical breather and tin cap (Sprite?). £35
4) Pre A+ 1275 primary gear. £50
5) 1128 gearbox (AD016), complete (part stripped). Case looks good, some of the dog teeth are worn, 3.65 diff. £125
6) Set of high compression A+ series pistons, used but very little wear evident, no rings. £30
7) Wavy grille – 'original' as far as I can tell, very nice condition. £65 (SOLD)
8) Mk1 headlining frame with modern black lining. £50 (SOLD)
9) Mk1 rear screen, good £50
10) Mk1 rear quarters lights (pair), not piano hinge – stainless? Decent condition but seals needs attention/replacement and a bit of rust on the external catch bracket. £175
11) Mk1 front door glass set, one piece has been etched. £35
12) Set or iron door hinges, blasted and in etch primer, reasonable but could do with re bushing. £40 (SOLD)
13) MS grille whiskers, unused. £10 (SOLD)
14) MS Speedwell Cobra seats complete with sub frames, used for 50 miles - as new condition. £300
15) Mk1 wiring loom (front and rear) from ‘66 car, needs work but has some good parts, bulb holders etc.– spares or repair. £40
16) Door pull - chafing to plastic casing at one end otherwise good. £15 (SOLD)
Small parts can be posted at cost. Glass and big parts pick up only or I may be able to get them to Notts area mid to late December.
(Cumbria)
(Cumbria)
Re: Multiple Parts
Hello, send you a PM on a couple of parts.
Re: Multiple Parts
List updated.
Will listen to reasonable offers on the remaining parts
Re: Multiple Parts
Hi Jono,
Where are you based? I'm interested in the mk1 headlining frame.
Cheers, Carl
Cheers, Carl
Re: Multiple Parts
Unfortunatley I'm in Cumbria Carl!
..though I may be able to get it down to Nottingham before Christmas - as you probably recognise it's not an easy thing to send
Re: Multiple Parts
Thanks for the reply jono, i have a friend coming upto appleby over christmas, is this anywhere near you?
Re: Multiple Parts
Can I buy the door hinges please.
Re: Multiple Parts
Sorry Nick, I think the hinges have gone.
Re: Multiple Parts
Carl - Appleby is certainly doable as a drop off point.
PM me if you want to proceed.
J
J
