mk1-forum.net
It is currently Fri Dec 14, 2018 10:54 am
For Sale Section Rules
1) This section is for advertising items that you have for sale. Not for the discussion of listed items. If you wish to debate the pro's & Con's of any item listed, please start a new topic in the appropriate section.
2) If you have items for sale on ebay, please post them in the appropriate section. This section is NOT for the advertisement of your ebay auctions.
5) Items listed for sale should WHEREVER POSSIBLE* be offered with a purchase price, not asking for bids from members. If you wish to auction your item to the highest bidder I would suggest you use ebay & pay the associated fees.
6) This section is offered as a free service to enthusiasts. Any deals made are between the buyer & seller only. The MK1 forum takes no part in any transaction & the appearance of any item in this section is not a recommendation. I strongly suggest that both buyers & sellers are happy to proceed with a deal before any money or goods change hands.
7) It expected that members contribute something to the forum before posting for sale advertisements. Any Adverts placed by members with a post count lower than 5 will be deleted.
8) The advertising of or soliciting for VIN tags, log books or any other vehicle identification documentation without it's associated vehicle is expressly forbidden.
9) If a moderator considers any postings in this section to violate either the spirit or word of these simple requests the MK1 Forum reserves the right to delete any posts without prior warning or explanation.
10) The posting of items for sale on the MK1 forum constitutes explicit acceptance of these simple rules.
* In some cases it may not be possible for the seller to list items with a sale price. In this case, listings will be reviewed on a case by case basis by a moderator. The moderators decision will be final.
Rev 2.8 (28.11.18)
Post new topic Reply to topic  [ 11 posts ]  Go to page 1, 2  Next
Author Message
PostPosted: Fri Oct 12, 2018 5:16 pm
Offline
Clearing Garage ..pm me your email & i will supply photos of the "used" item.all Plus postage "MAKE OFFERS" as next is to go on eBAY
.Competition steel Water pump Pulley 4.5 inch o/d @ £40
2. Clutch Alloy Cover 22G271 ..radius on starter cover. @ £20
3. Clutch Alloy Cover 22G271 VF5 ..radius on starter cover @ £ 20
4. Clutch Alloy Cover 22G271 Birmal.. Square end to starter cover.@ £20
5. Bell Housing ventilated 22G1556 Bimal @ £35
6. Brass Block Drain Tap @ £15. two available but not tested.
7. Purolator Oil Filter Housing assembly @ £ 10.
8. Rear Steel Suspension Trumpets with original Cones @ £35
9. Pressed Rockers on assembled shaft @£10.
10. 22G 1128 Gearbox Case note right side drive coupling has rubbed the main case , but not holed .. helicoil sump plug needs refresh .. the under side fins are in very good condition @ £100 ( there is no remote gear houseing) .. Uk Postage £12
11. Remote alloy Gearchange complete with shift shaft @ £45 .. Uk Postage £12
12. HIF 44 Carb + Water Heated Manifold + Throttle Cable +K&N Filter @ £120 + £12 UK Postage
13. 1275Gt Steering Wheel & Silver 1275 Gt Badge .. not perfect example but good useable condition SOLD
14. Floor Starter Solenoid complete with Top Bucket & Button Date 8/61 @ £40
15. Ignition Switch ( none starter type) date 8/61 Key No FP 636 no key supplied @ £30.
16. NOS 2 x Front Brake Hose Unipart GBH102 Mini Saloon & Contryman1959-67 /Cooper 1961-67.. two new brake hoses in Tatty Unipart Boxes £10 + £3.50 post in UK
17. NOS Alternator Fan 6inch OD 2 off at £10 the pair + £3.50 UK Post.
18. NOS Alexander Short Ram Pipe ( short length- meshed intake) suit 1,3/4 inch SU or Stomberg.. one old stock item in original tatty box @ £25 + £3.50 UK Postage.
19. Operation Book for Leyland Mini 850/1000 ( used but in good condition) Nuffield Press 29/77 @ £10 + £3.50 post in UK
20. ADO 16 remote change "Adaptor Casting" to fit to rear of gearbox in good condition..( This Casting that has the horizontal connect holes not mini) £30.
21. 1 x NOS gear change "Shaft" this long shaft has the spline on one end & has the hook shape on the other end &(fits inside the 22A250 remote casting)@ £20
22. 3.5 inch "S Wheel Rim".. not the best .. in primer and would make a good spare @ £55 + £12 UK postage.
23. Reclining Front Seat in Green .. has ball end to recline lever & probably from Elf or Hornet (std looking seat not works recliner).. small hole in base of rear cover & needs refresh £75 + postage
Last edited by Polarsilver on Tue Oct 23, 2018 12:29 pm, edited 14 times in total.
Top
 Profile
 Post subject: Re: Used Parts
PostPosted: Fri Oct 12, 2018 5:56 pm
Offline
Will pm you later but will have voltage reg posted please :D
Will shoot loot over after advice on postage costs
Jeremy
Top
 Profile
PostPosted: Fri Oct 12, 2018 6:20 pm
Offline
Regulator Sold thanks Jer.
Top
 Profile
PostPosted: Fri Oct 12, 2018 6:22 pm
Offline
Hi, PM sent about 13.
Angus
Top
 Profile
PostPosted: Fri Oct 12, 2018 6:37 pm
Offline
Angus.. you have pm re item 13.
Top
 Profile
PostPosted: Fri Oct 12, 2018 7:05 pm
Offline
Am interested in the water pump pulley, will pm you
Top
 Profile
PostPosted: Fri Oct 12, 2018 7:18 pm
Offline
Interested in the piston ring set.
Can you tell me the Hepolite/AE part number so I can check the application.
Andrew
Top
 Profile
PostPosted: Sat Oct 13, 2018 7:16 pm
Offline
Would take the remote gear change if available
Nick
Top
 Profile
PostPosted: Sat Oct 13, 2018 9:13 pm
Offline
Nick, you have pm.
Top
 Profile
PostPosted: Mon Oct 15, 2018 12:27 pm
Offline
All sold items have been posted many thanks Norman. :)
Top
 Profile
Who is online
Users browsing this forum: BLT and 2 guests
Search for:
Jump to:
