Back at it and first order of business was to get the footwell closed up
Next up was fitting the inner A-Panel, which meant sticking the wing and Bonnet in place in order to see if it was anywhere near being close to where it should be. It wasn't so much fiddling was involved.
Panel gap looks ok on this side, but without the front panel on, it's anyone's guess how much work it will be to get this gap when the front panel goes on. For the moment I am happy
Right side will take some massaging to get fitted...
Although the scuttle gap is coming together, it was way out (3/8th of an inch when I started fitting the wing)
Anyhow, back to the side I am working on...
Happy with the inner A-panel, we fit the outer and check the door gaps
A-panels spot welded and the door is hung
