Mini baby mk1 1967
66S
Re: Mini baby mk1 1967
Post by 66S »
Pull the sticker off the washer bottle, it shouldn't have one. I am also wondering if the distributor cap should be a side entry type and the spark plug caps should be Champion WC548's That is about all I can see, lovely job though.
Al
ricardo
Post by ricardo »
Also fit the ignition panel the right way (it's upside down) and I think it shouldn't have the chrome surround (?).
Charlynsane
Post by Charlynsane »
Hello
As for me she used to have WC200 spark plug cap??? no the early wc548 type.. isn't it?
And this is the good distributor cap, because it's one of the latest mk1 produced,
what do you mean for the ignition panel??
thank you
Charles
Charlynsane
ricardo wrote:Also fit the ignition panel the right way (it's upside down) and I think it shouldn't have the chrome surround (?).
windscreen surround??
Charlynsane
hello
Another picture of the car taking the sun
Uploaded with ImageShack.us
As for me the 850 mk1 used to have chrome trim arround the ignition and switches panel,
For the sticker I'm unsure, It's not difficult to pull it, as for me it was fitted on mk1/2 washer bottle,
About plug cap, I'm looking for its original wc200 caps,
Does anyone have this?
I think the ignition panel is correctly fitted, I don't understand how to fit it differently??
66S
Post by 66S »
Charlynsane wrote:hello
As for me the 850 mk1 used to have chrome trim arround the ignition and switches panel, Depend on build level, Basic, Deluxe etc
For the sticker I'm unsure, It's not difficult to pull it, as for me it was fitted on mk1/2 washer bottle, Mk1's and 2's did not have stickers
About plug cap, I'm looking for its original wc200 caps, I personally think a Mk1 should have WC548 caps, WC200's were later
Regards
Al
ricardo
Post by ricardo »
I believe the ignition panel is upside down, you should turn it 180 degrees. I'm saying this because:
- The ignition barrel is upside down (it has a flat on one side, so can only be mounted one way... unless it was modified).
- The recesses for the choke and heater cables seem to be upside down too.
AFAIK late MK1 850 Minis didn't have chrome trim surrounds around the ignition panel.
Since yours is an export model, things may be different.
However I agree with Al, your car originally wouldn't have WC200 caps as they only appeared in the 70's.
cpr1
Post by cpr1 »
i have seen original mk2's with WC 200 caps.
Charlynsane
ricardo wrote:I believe the ignition panel is upside down, you should turn it 180 degrees. I'm saying this because:
Hello
I will wheck the ignition panel today,
For the chrome trim she used to have it before restoration,
And she also used to have wc200,
As for me wc548 was used until 67, and on late 67 they used to put wc200
Thank you
Charlynsane
hello everybody,
the tudor sticker has been removed,
And I put a new detail the "coopers" sticker of the air filter housing,
i found it on sommerford-mini
And next time I will fit the wc200 spark plug caps,
I'm waiting for it!
Charles
Charlynsane
Some news:
wc200 are fitted:
I have also stuck the original sticker for the coil..
I think, the car is now finished!!
cpr1
Post by cpr1 »
wc200 are fitted:
nice ht leads you have there Charlynsane. ;)
Charlynsane
thanks you for your kindness Raymond!!
They are perfect!!
I'm still looking for nicer seatbelts eventhough she has the original ones!
I'm looking for Kangol or Britax
Charlynsane
Hello guys!
Some news of my little car!
Today the weather is sunny! let's ride!
Another news
I finally found the return spring anchor for my HS2! It's NOS thank to "union-jack"
I sprayed it with black epoxy and fitted it!
I think the car is now finished!
Charlynsane
Hello guys!
Summer is coming I'm worked a little bit on my old Lady
I finally found a perfect cavity wax spray gun!!
It goes everywhere! trough the vents of the sills and everywhere!
I also retrimed the wheel arch cover that where cracked!!
It looks better in reality.. it's yellow because of the flash of my phone
I'm also looking for a seat cover..
I searching for 2 years but it seems to be very difficult to find this!
I used the car 2 weeks ago,
What a pleasure!!
Cheers guys
Charlynsane
Some updates!
I found and fitted door edge trims!
The car is ready to hibernate during the winter!!!
I 'm still lokking for a good front seat cover but it's difficult!
bpirie1000
Post by bpirie1000 »
Brill.... Just brill... Motivates me no end.... To the garage............
That looks fantastic!
I hope that you manage to find a replacement front seat! At one time this would have been easy, but I guess that most of these seats must have been thrown out years ago. :cry:
Charlynsane
Hello Guys!
Thank you for your comments!
I spend a lot of time on this car but now, I think it's finished!
I found the door edge trim at sommerformini!
I'm still looking for a front seat Mark,
I tried everywhere, but I didn't find it.. I used to avoid newton trim but, I will have to deal with it
I also tried to send a mail to Miniworks but they don't have it
I'm also looking for an original spark plug spanner, if someone has it for sale??
Charlynsane
Lucas prince of darkness!!
I was driving yesterday to get my girfriend,
When suddently no flasher, no front light and the fuel gauge started to swing..
So we went to home, I started to check all the bulbs and and connectors,
One connector of the headlight was not welded properly, I welded it, the front lights were ok but the fuel gauge and the flasher was swinging..
I move just a little my brand new chinese fuse box, And finally All was working properly..
I hate electricity!!
