Austin 850 Speedwell 1964
Re: Austin 850 Speedwell 1964
strip and degrease front subframe, nasty work
- Frogeye61
Nejs.
If you were Scottish I bet you could get at least 5 more years on that rubber bushing.
Don't tempt me
Don't tempt me
More stripping
- Frogeye61
Body work has started this week.
Work on the body is done by retired BMC spare parts Manager Mogens Christensen
Started on a set of 998 con rods , for my engine project.
First picture is std 998 rod. at 694g
Second is 43g lighter
- Frogeye61
Very nice. Following that with shot-blasting would also be advantageous.
I did some more lightning today. Started work on a block, that I used some 18 years ago.
Found it in the garage, looking for a spare engine for my project. (I have many engines and parts in there).
Think I used it with a 12G295 head with 33/29 valves, as the blok has cut outs for exhaust valves.
I have taken 4mm out of the bores, and 2mm of the top for a start.
I like them big... BIG!!!
Who said that. at 2.45 : http://www.youtube.com/watch?v=Ng7_eHnY ... re=related
I also like them big... BIG, the bores i mean.
Yesterday I got some Hypatec 998 +100 = 67.10mm "big" small bore pistons from australia.
Maybe too big (see pic.). I will try to make some sleeves next week.
e-type wrote:I like them big... BIG!!!![]()
arggg!!!! speedhole
Bodywork progress:
Front is now fitted, not the best fit though
Now it is time for the floor
The companion boxes has been cut and welded, before i got the car.
And then painted a non matching blue.
I have ordered new.
I have ordered new.
Fixed the oil spray holes on cylinder No. 4 with some sleeves today.
- Frogeye61
Yes, honing to 67.12mm = 966cc with 850 68.26mm stroke. almost a 970
Speedwell did a 962cc overbore, so this is the closest I could get.
That's interesting, how did you do that? I thought you would have to sleeve and re bore?e-type wrote:Fixed the oil spray holes on cylinder No. 4 with some sleeves today.
Looks like a repair from the back???
Please explain
Yes I drilled out the oil pressure valve hole, and fitted a small sleeve/liner. Did the same with the hole the oil pipe connects to.
At the face of the block, the oil pressure hole was 8mm, but where it broke through to the bore of cylinder No. 4 it was almost 9mm.
Not the most accruate machines they used back then at BMC.
So had to drill out to 9mm all the way, to get the sleeve in there.
