Time lapse of “Brittas Cooper” Restoration
Dr.Mabo
Been thanked: 27 times
Re: Time lapse of “Brittas Cooper” Restoration
Post by Dr.Mabo »
Another modification are housings for dashboard speakers.
The speakers should stay as flush as possible with the speedo panels to keep the classic look. I beat the metal in to a shape of half a ball.
so long
the Doc
My previous project:
Dr.Mabo
Post by Dr.Mabo »
Then I build a ring to extend the housing and to form the flange for the speaker.
That's it for today
the Doc
so long
the Doc
rich@minispares.com
Post by rich@minispares.com »
im starting to like the custom modifications to this car - I will let you park it next to the er-cooper s when its done :lol:
the 'er' has a mk3 heater in it with the plastic pipe through the inner wing. it certainly keeps the engine bay neater
Dr.Mabo
Post by Dr.Mabo »
Other modifications to the inner wing:
• Service hole for brake hose on r/h side
• Service hole under shock absorber bracket for corrosion protection. This will be covered by the bracket and sealed with flexible sealing compound
• all unused holes closed
• and an 18 mm hole in the r/h inner wing inline of the crankshaft. This allows, in case of clutch replacement, to undo the flywheel nut with a proper and powerful ratchet from the wheel arch.
so long
the Doc
Dr.Mabo
Post by Dr.Mabo »
R/H inner wing fitted to the front end.
so long
the Doc
Dr.Mabo
Post by Dr.Mabo »
And the L/H inner wing went in too.
Inside the A-post and the sills I used “Mike Sanders” anti corrosion grease before I closed the sections.
I love to work with a spot-welding-gun.
http://www.mike-sander.de/
Just click on the British flag to get the page in English.
so long
the Doc
so long
the Doc
swifty
Been thanked: 12 times
Post by swifty »
Very competent work . Well done . Like the speaker mods ... Ken
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
Dr.Mabo
Post by Dr.Mabo »
swifty wrote:Very competent work . Well done . Like the speaker mods ... Ken
Thanks Ken
so long
the Doc
GraemeC
Post by GraemeC »
The brake hose access hole is a good shout - I'll be doing that next time I have to work in that area.
For the flywheel bolt hole I went big enough to get the socket through, much less messing - also gives plenty of scope to get a twating bar in there and give some wiggle room for misalignment if you haven't jacked the engine up by the same amount each time too.
Remember the holes in the subframe to get to the wok bolts ;-)
rich@minispares.com
GraemeC wrote: a twating bar
is that a technical term??
:lol: :lol: :lol:
GraemeC
Post by GraemeC »
Of course - I'm sure you have a few.
To be used in conjunction with various calibrations of testing stick!
Dr.Mabo
Post by Dr.Mabo »
Later I fitted the outer A-Panels and aligned the doors. But I wasn’t happy with the radius of the lower quarter panel. Hence I corrected the radius according to the shape of the door.
so long
the Doc
Dr.Mabo
Post by Dr.Mabo »
There was also some work at the rear side quarter window frames. A bit of cutting, beating and puzzling and the frame was nice and free of corrosion. Same on the other side.
So long
the Doc
so long
the Doc
swifty
Post by swifty »
That's great work , very neat ... Ken
Porsche 997 turbo S
I am from Essex
Dr.Mabo
Post by Dr.Mabo »
Some more modifications of the floor section.
I have seen plenty of terrible cutouts for the remote gearbox. This is the correct shape for MK2 and MK3 Minis.
I extended the inner groove on the right hand floor by about 5 cm to use it as a cable channel.
As you may notice on the photo I also turned the cross member around. Now the seat mounts are on the rear side. That gives a comfortable seat position for tall drivers and passengers without those funny extension adapters :lol:
so long
the Doc
so long
the Doc
spoon.450
Post by spoon.450 »
Fantastic work.
rich@minispares.com
that COULD have been one of those 'ohhh fuuucccccckkkkkk' moments couldn't it! :lol:
GraemeC
Post by GraemeC »
Not yet Rich, that wouldn't come until after the paint was on, carpet in and you were lifting the first seat in the day before the MoT was booked.....
rich@minispares.com
GraemeC wrote:Not yet Rich, that wouldn't come until after the paint was on, carpet in and you were lifting the first seat in the day before the MoT was booked.....
of course, how short sighted of me! :lol: :lol: :lol:
STG95F
Post by STG95F »
Was MK1 Cut out different to MK2 & 3 then ??
