64 Austin Cooper S 1071.
scott6058
Re: 64 Austin Cooper S 1071.
Post by scott6058 »
Hi Masnarda
Things are on hold still with my 1071 I have a major money pinch but I still have a job :P
Like you,, liners were an after thought but very worthwhile so it will happen.
Saving also for a M Machine floor pan also an important must have.
I won't have the funds till May 11 then I would like to share some pictures.
Curious as to which pistons suit the best with the offset pin of a 1071 ?
I'm learning very much from this site. Thanks
Scott
skorstensfejeren
Post by skorstensfejeren »
The inner wings is on....
Last edited by skorstensfejeren on Thu Feb 16, 2017 11:46 am, edited 1 time in total.
skorstensfejeren
The front, and front wings are now on
skorstensfejeren
Fits great.... :)
skorstensfejeren
The front and wings fits great....
skorstensfejeren
Front and wings....
skorstensfejeren
The end of the crossmember is replaced, and filled with tin after welding it together.
skorstensfejeren
Right floor is on. after welding together, tin is on.
skorstensfejeren
Floor is on. after welding together, the most of the welding is grinded off, and tin is added.
skorstensfejeren
Here´s also some photos from my heater rebuild.. its always nice to have something to work on between the body work ;)
skorstensfejeren
The parts are sandblasted....
skorstensfejeren
The heater comes apart...
skorstensfejeren
The engine will be cleaned and tested...
skorstensfejeren
The original letters that is painted on, will be saved before sandblasting
skorstensfejeren
Spares are painted with primer....
skorstensfejeren
The front and corners are painted with crackle paint...
skorstensfejeren
Spares are painted in satin black......
skorstensfejeren
The heater....
skorstensfejeren
Getting the heater back again....
skorstensfejeren
New foam on the metal plate.
