did they all fall to bits.
How would you manage that! if it wasn't welded/glued on the inside the whole thing would fall apart before you even finished cutting off the seams!!36inter wrote:Probably all fell apart judging by the state of some I have seen. One in particular just cut the seam off and put filler in the gap!!
Pete
Seen some bodged years ago with filler outside + fibreglass matting and resin from behind or aluminium sheet plates and csk head pop rivets being used to hold the panels together behind and a skim of body filler on top over the join.......minimans wrote:How would you manage that! if it wasn't welded/glued on the inside the whole thing would fall apart before you even finished cutting off the seams!!36inter wrote:Probably all fell apart judging by the state of some I have seen. One in particular just cut the seam off and put filler in the gap!!
Pete
..just like flares and tank tops !!!Blue Mk2 wrote:I haven't seen a de seamed mini for ages. I remember seeing them now and again especially at mini 30 Silverstone. Quite a number were mk1 s
underkut wrote:I.
What i did notice recently when i painted the inside is that all the weld marks became visable on the inside,i was amazed at the complexity of bits needed to make up the rear pillars by the rear window,lots and lots of little bits needed to get the shape.
.....and just as Mark suggests - it seems to contain a fair bit of water
