Sorry to be a drag, but if you could spread the word?
Bitsilly
Post by Bitsilly »
Hi all,
Some of you will know of my current problems of my car being permanently taken off the road because I drilled holes in the boot as part of the electrification.
This new application of the DVLA rules, if extrapolated or not, will cause all sorts of problems for classic car owners, not just electric ones.
I have drafted a letter, which is long but says it all.
If anyone out there knows any motoring journalists, editors, civil servants etc etc please could you forward the letter on to them. Alternatively let me know and I will forward it but this may take a little longer currently
A relevant selection of photos is also available, which can be sent to any e-mail address you want, anything else is currently beyond my ICT ability!
Like I said, sorry to be a drag, but I really think this idiocy should be reported and addressed.
Writing the letter was very cathartic, which I really needed!!
Please feel free to change it as you see fit, although my wife told me dripping sarcasm, crude expletives and personal insults are not allowed (even when totally justified!).
Cheers in advance.
Ed
the letter:
Dear .......
I apologise for any intrusion, but I feel it important to inform interested parties of the implications of a recent change the DVLA has made to its interpretation of government policy.
The change will bring an abrupt halt to the growing industry of converting classic cars to electric power simply because if any hole is drilled as part of the conversion, then an IVA test will be required.
Additionally, once an attempt at electrification is made and the DVLA is informed, they will confiscate the existing V5, delete the car's Vin number from its data base, and, through insisting on an IVA test, cause the death of many classic cars.
They have also decided that reversal of such works and/or the cancellation of any application is no longer allowed.
I refer to a recent case of the electrification of a 1960 mk1 classic Mini, (their ref. 96628439 Davieslg Kits D9) which seems to have been a test case for their policy change.
Photos can be forwarded if you wish.
This conversion was done with the collaboration of a leading specialist firm's MD, a Doctor of Engineering who developed the electric Transit van for Ford, and by myself, a retired automotive engineer and current car restorer. We like to consider it a far cry from a teenager fitting a flip front and a Vtech engine to a classic mini, or perhaps a motorbike engine in the back seat or a custom rear cradle, all of which have previously been approved by the DVLA.
The entire ethos of the project was to keep the conversion 100% reversible, and to demonstrate what can be done even within such a restraint.
Previous to this case, following an electrification, it had been sufficient to submit the V5 to the DVLA with the 'change of engine' section filled out.
This was done, but instead of a new V5, we recieved a lengthy questionaire asking things such as 'what is the new electric motors cubic capacity'.
When it was pointed out that these questions were unanswerable, the DVLA decided that now, in such cases, they should be applying the rules of their 'Kit cars and Rebuilds' department.
An inspection was arranged, and the greatly impressed but rather confused inspector insisted that there would be no issue in retaining the car's identification.
The DVLA office based staff did not agree with the inspector's opinion and concluded that the previous registration is now invalid and that its identity must be voided. They stated that, "The car requires an IVA and if successful will then be issued a Q-plate".
The reason given for this was that a hole had been cut in the monocoque, in the boot lid behind the hinged number plate.
Following a request for clarification when we pointed out that the boot lid was not part of the 'monocoque', they conceded this point, but now said the problem was that holes had been drilled in the boot.
We offered to weld up the holes, but this was not acceptable as they said nothing can reverse such a 'radical modification' like drilled holes. Reversal, however it is done, will not reverse their decision. An IVA test is needed.
Unfortunately, it is not possible for a classic Mini, nor most other classic cars to pass an IVA test due to their design and manufacture, and the complex nature of the test. An IVA was intended as a tool to judge a modern kit car with a design focussed on passing the test, not to judge a car designed in 1959 and built in 1960.
The Mini, for example, has external welded seams, exposed trim and steering column and edges consided 'sharp' throughout. The major, costly and radical modifications, even if possible, would still be a waste as the design would simply fail on too many other points, and also because its failing features can only be changed by 'methods currently used by mainstream car manufacturers'.
The irony, that because they find unacceptable the incredibly minor modification of a drilled hole, that they must insist on many more radical and serious modifications is curiously lost on the DVLA.
Additionally ironic is that in their own rules as published on the .gov site, in for example "converting a 'box van' to a 'camper van'", an IVA, is not usually required, but the conversion must include modifications like at least two windows being cut, and ideally the roof removed to fit an concertina type roof, so as to ensure the vehicle resembles its new (un-tested and un-inspected) description.
So this is where the case has currently concluded. The car has no legal future other than to be scrapped for parts, although even this is difficult as one is obliged to surrender the V5 to the ATF (Authorised Treatment Facility) while retaining the yellow section. Difficult when they have refused to give it back.
We would greatly appreciate any assistance you can offer to help the DVLA see how it can apply their rules in a more realistic manner as quickly as possible, to prevent more cases like this, and to prevent them choosing to extrapolate on this change of policy and insist that other electric classics or classics with holes, drilled, caused by rust, or otherwise, must now have an IVA test.
We would like the DVLA to adopt the common wisdom that:
* to safely electrify a classic car it is reasonable and necessary to require safely drilled holes.
* that welding is an ongoing requirement for keeping classic cars road worthy, so should be allowed as a way of reversing drilled holes.
* that where one drills holes is admittedly very important, but that a Doctor of Engineering would possibly know better than office administrators on where and how this can be done safely.
* that when an appropriately qualified experienced automotive engineer, intends to make any change to a classic car 100% reversible, that they are capable of and able to ensure that this is the case.
* that drilling a hole in a car's boot should not be described as a 'Radical Modification'.
* that if an application fails the application can be withdrawn on the condition of an inspection to prove originality.
If you agree that their current policy is a mistake, any assistance or advice that you can offer to help appeal or reverse the death of this Mini would be appreciated.
If it is not deemed a mistake then I am afraid that the future of electrification of classic cars and classics with very minor modifications, is at serious risk.
Even if you cannot help, please pass on this information to stop anyone else becoming an out of pocket victim.
Please just ask if you would like any further information, photographs, or copies of the correspondance with the DVLA.
I am happy for any publication or journalist to contact me directly should they need any further references or details​
Many thanks for your attention to this report.
Kind regards
Ed Keane BSc BEng
PS. I would love to say I have exaggerated the simplicity of the problem or that common sense will prevail, but this case has already been ‘elevated’ within the DVLA. The department of transport , the All Party Parliamentary Group on Historic Vehicles, Trudy Harrison, and other MP's have been informed but as yet have not responded.
Pandora
Re: Sorry to be a drag, but if you could spread the word?
Post by Pandora »
I'm pals with Nigel Boothman, who is now editor of a Rolls / Bentley magazine, but as a freelance worked on a lot of the Emap titles (classic cars etc) until recently. I'll let him know and see if he can do anything in terms of spreading the word.
Al
Bitsilly
Post by Bitsilly »
Nice one , thanks!
Polarsilver
Has thanked: 32 times
Been thanked: 47 times
Post by Polarsilver »
Contact the BBC or ITV your local Wales TV news stations.. our local TV news are always asking for a story they should cover .
Costafortune
Has thanked: 30 times
Been thanked: 37 times
Post by Costafortune »
I've forwarded it to a couple of classic mag editors I know.
Bitsilly
Post by Bitsilly »
Cheers, my raison d'être is expanding.
Many thanks!
Costafortune
You have pm/email.
woodypup no 2
Post by woodypup no 2 »
Karen or kay drury at mini mag ?
Ronnie
Has thanked: 9 times
Been thanked: 25 times
Post by Ronnie »
well Prince Charles has not had any problems keeping his number, but the conversion ( fuel type ) was done by Aston Martin :?: But what is the fuel duty on wine & cheese :?: :shock: :o
Also send some facts with regards your dilemma to your MP :!: Surely they (possibly an office junior) at the DVLA cant really infer that a few holes have altered the structural integrity of your shell, when their motor vehicle engineer (inspector) stated that " he represents the DVLA and he thinks the conversion is an excellent engineered thing and that there will be no issue whatsoever." Ask them for their calculations :!:
Best of luck :!:
Bitsilly
Post by Bitsilly »
true, the engineer really was very complementary of the conversion and stated 'I am the representative of the DVLA, and if I say you will easily retain your plate, then that is what the DVLA say'.
Turned out to he was over-ridden by desk based bureaucrats!
The E-type that that posh bird and bloke rode in at their wedding obviously never had anything drilled in it! No pun intended.
To date they will not release the report to me and though I have the engineers contact details he is not at liberty to release confidential DVLA reports.
As Mark once said, what total bo@@ox!
Pandora
Post by Pandora »
I think you can ask for the report under FOI. No reason it should be confidential as that usually relates to commercial sensitivity, and as a Govt dept they are non commercial.
I have previously made FOI requests to HSE (my former employer) for fatal and serious accident investigation details, and they have been released, or at least the factual parts, if not the 'opinion', so it may be that some is redacted, but there should be enough to show you his conclusions.
Costs nothing to put a request in
Al
Bitsilly
Post by Bitsilly »
That is now something I will do Tuesday!
rolesyboy
Has thanked: 15 times
Post by rolesyboy »
As I recall they are duty bound to respond within 21 days for any FOI request. They may choose to redact certain elements of the report
Has thanked: 18 times
Been thanked: 49 times
Sorry I missed your call - will email ;-)
Has thanked: 225 times
Been thanked: 190 times
Brief details and a link to this topic posted on 'The Mini Forum' (TMF) :-
https://www.theminiforum.co.uk/forums/t ... nt-policy/
mk1coopers
Post by mk1coopers »
There’s been some interesting replies on TMF, including one about clickbait which I’ve just replied to, this really needs fighting / getting the classic car press etc on board will help, as other have said, fit an aerial and you ‘could’ loose the identity of a car, yet you can cut big holes in the side of a monocoque van to make it a camper with no issues :roll:
Ed, Please can you send me the photos & I'll post them up so anyone can print them off if needs be. I'll also be forwarding it on to a few people I know.
Hippo
Post by Hippo »
Ed don’t know if this line of enquiry is of help, taken from this weeks classic car weekly
1968 Cooper
1964 Pick up
BucksMk1
Post by BucksMk1 »
There's a number of businesses who offer these conversions and seemingly don't have any difficulties. 'Vintage Voltage' being one with quite a high profile. Is it worth contacting a few and while raising awareness of your situation, understanding how they can be converting vehicles without these issues?
1965 SDL. 1 prev keeper & matching numbers :D
Bitsilly
Post by Bitsilly »
A number of them that Nick has been in touch with and ecoclassics are putting together a focused defensive involving their mps etc. it is the more litigious approach but in parallel to my approach.
They have all suddenly had a lot of problems similar to mine, which they had not had up until now, which reinforces the idea that dvla have changed the application of their rules.
These businesses have a lot more to lose than I!
