1967 Le Mans Mini Marcos survives, too
Jeroen Booij
Post by Jeroen Booij »
I can't believe I haven't found out this any earlier as it was under my nose for many years, but I think I have now found out where the 1967 Le Mans Mini Marcos is.
The car is claimed to be in Zimbabwe but there has been doubt about its authenticity for many years.
I believe this is the proof to debunk it:
http://maximummini.blogspot.com/2020/06 ... rtons.html
http://www.maximummini.blogspot.com
- the definitive Mini is a derivative -
Re: 1967 Le Mans Mini Marcos survives, too
Interesting - some good comparisons!!
;) very good news Jeroen
Kees
Mini 1000 Super de Luxe Mk3 1974 for Downtoning it.
Pete
Post by Pete »
That’s good new Jeroen! It’s the opposite with Unipowers, we’ve pretty much put to bed the idea that either of the two Le Mans Unipower GTs survived, contrary to what we’d been told for so many years. :roll:
Jeroen Booij
Thanks Pete.
Meanwhile, the chaps in Africa have been woken up and they've come up with some very interesting info and pictures, which makes things even more complicated now! That only makes it more difficult now as there are two cars which both have their pros and cons or so it seems to me.
Not such a muddled mess as with the Unipowers though!
I don't think the Japanese car is the Le Mans car. The windscreen is not high enough and the orientation of the fuel cap is wrong.
I know the perspective is not the same but if you draw a line up the quarter light and on towards the screen corner it show the difference in the screen positions. Also the a-pillar appears to be wider on the Le Mans car. Also the rondel lights are bigger on the Japanese car.
Has any body seen a dog dyed dark green?
Jeroen Booij
surfblue63 wrote:
Mon Jun 29, 2020 10:07 am
That's very good Surf. The plot thickens more and more with more stuff coming over from Zimbabwe.
Apart from there, I have a few things on my list to check next: the ACO, the owner of the car in Japan and the supposed owners of the FLIRT-car. There's more to follow.
coopersean
Post by coopersean »
I agree with Andrew - the window frames look slightly thicker and the small front quarter light look to be in a slightly different position.
The door roundal lights on the Japan car looks to be in line with the door handle, which looks slightly off set on the Le Mans and Africa car?
More pics of the Africa car here:
https://www.minimarcos.org.uk/minimarco ... index.html
The other point I forgot to mention are the rolled sills on the Le Mans car. Both the cars claiming to be the actual one do not have the rolled sills. These may have been an add on, like the rear arch spats,, but why have they been lost.
Also neither has the correct rear lights. The Le Mans shots show three units of the same size on each side, the Japanese car has two large and one small, and the African car has one large and two small.
The screen on the African car looks to be too short and in the same position as the Japanese car, and the rear arches on the African car seem to have been widened.
Is it possible that two cars were used at Le Mans
This shot is of the car during the Le Mans test 9th April 1967 when Tim Lalonde drove, hence the number 51, the car wore the No.50 in the race as seen in the other pictures. Also this looks to be prior to the roof being modified.
In favour of the Japanese car there appears to be a slight shadow above the B-pillar, in-line with the modded roof on the race car. You can also see that the roof mods were rivetted, and possible these were removed and the roof returned to a stock position.
Costafortune
Post by Costafortune »
Sorry, but they're two different cars.
