Steering Wheel Refurb.
DB1380
Post by DB1380 »
Ive got a 14" Astralli wheel in my car, it had a few marks on it and i quite fancied the wood rim darker.
Much sanding down, staining etc, i got this. Very pleased with the end result.
KPB 729C 65 Mini Minor 1380
Location: Sunning myself on my top secret tropical island.
Re: Steering Wheel Refurb.
That looks great!
Good job done.
Forum founder, backer & only admin for nearly 20 years.
I Must be f*&%^g mad
Very nice job, well done.
Kees.
Downton Sport40 replica Classic Mini 04-2000. Still FOR SALE !
Mini 1000 Super de Luxe Mk3 1974 for Downtoning it.
:D Well I did also an Formula steeringwheel from the 70th the otherday ;)
Kees
AndyB72
Post by AndyB72 »
Nice job, I want to do this to my LL wheel so it matches my darker burr walnut dashboards. How did you apply the stain to get a nice even finish, did you spray it on?
DB1380
Post by DB1380 »
AndyB72 wrote:
Tue Mar 24, 2020 10:04 am
Hi Andy, its a lot of work but well worth it.
The worst part was sanding the original lacquer off back to bare timber...took a good couple of hours to do. Then finished off with fine Wire Wool.
The stain i used is "Rustins Dark Oak Wood Dye". Gave it 5 coats, just put on with a clean cloth. Dries very quick, you can do the 5 coats in 20 mins.
More coats you give it the darker it will get. After i was happy with the colour, i then gave 4 coats of rattle can Upol Clear Coat. Then a clear wax and buff up.
Give it a go, enjoyable to do. Im a Carpenter by trade so do stuff like this all the time.
Dicky.
AndyB72
Post by AndyB72 »
Thanks Dicky! I'm re lacquering another wheel at the moment and its coming up really well, has taken a while but as you say very satisfying.
I've tried paint stripper on the Les leston wheel I want to dye but it hasn't touched it, maybe need to give it some elbow grease instead.
Paint stripper will only work after sanding it,
you have to make the surface porous otherwise
it will never work.
Kees.
I have done a few wheels over the years & most have come up well. I have found that there is no substitute for elbow grease though. I have never been a great fan of paint stripper on them as I have found that it seeps out of the join between the wood & metal after its been re-lacquered. :roll:
DB1380
Post by DB1380 »
I tried Paint Stripper....even the old proper "Nitromores"...wouldnt touch the Varnish on my wheel. Elbow grease is the only way. Dont rush take your time.
