mk1-forum.net
It is currently Sun Feb 23, 2020 8:32 am
Post new topic Reply to topic  [ 77 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8  Next
Author Message
PostPosted: Sun Jan 26, 2020 10:39 pm
Offline
ChrisM wrote:
Very nice work, and a stunning achievement.
Can I ask a couple of daft questions?
Firstly, did you have an estimate of what hp you hoped this would make?
Secondly - and I will say, I know absolutely nothing about fuelling and intake systems, was your inlet design with the single throttle body to achieve the OEM look you spoke about?
What would happen if you stuck a set of throttle bodies on that head? (Remember,I know nothing :D )
Regards: Chris.
Not daft questions.
I would hope 100-110 Bhp, Not going wild on performance, I want drivability rather than mad power. Will depend on final cam choice and displacement.
Single throttle body design you see fits under a standard hood, which was one of my original design criteria. Quad throttle bodies would give better power and throttle response but you would need a big power bulge! Would be better on a clubman...
Not sure where all this will go long term but it would be nice to build something a bit more radical sometime in the future.
Top
 Profile
PostPosted: Sun Jan 26, 2020 11:19 pm
Offline
Thank you. Really interested to see how this turns out.
Regards: Chris.
Top
 Profile
PostPosted: Mon Jan 27, 2020 9:50 am
Offline
Location: Unquestioning tool of the much misunderstood Mysterons.
That fits in beautifully.
_________________
Forum founder, backer & only admin for nearly 20 years.
I Must be f*&%^g mad
Top
 Profile
PostPosted: Mon Jan 27, 2020 12:27 pm
Offline
Superb work.
An option for engine management is to use Bosch Motronic. The complete ECU, loom, injectors, crank sensor etc can come from one of the many old 4 cylinder Vauxhalls or BMW's in scrapyards. You would need to adapt the crank pulley to take a signal for the crank sensor or you could fit a timing peg to the flywheel and mount the sensor on the clutch cover. The air gaps have to be absolutely spot on though.
They will all need a hole drilled and tapped in the head to take a coolant temp sensor.
1.3 doesn't have a cam sensor, made 1987-94. It had a fixed distributor with a cap and heads.
1.7 (16 valve 1992-5) has a cam sensor and a separate coil pack unit.
5.2 (16 valve 1995 on) was more advanced, replacing the air flow meter with a plastic hotwire MAF.
Anything after 1/95 needs the ECU sensing away to have the EWS (anti theft code) removed, about 50 quid.
This stuff is all available for buttons as well - I reckon about 100 quid for everything and it's all known proven stuff. It's knocking on a bit now so the time to buy stuff is about now.. :lol:
You'd need:
Loom
Throttle body
ECU
Crank pulley
Crank/cam sensors and brackets if fitted
Lambda probe (catalyst)
Air flow meter/MAF
Injectors and rail with pressure regulator
Coil pack and leads
Coolant temp sensor
Electronic fuel pump
Whatever I've forgotten.
Top
 Profile
PostPosted: Wed Jan 29, 2020 1:53 am
Offline
Chapter 4 “Does he really need all this equipment”
While all the packaging work was being done, I was also refining the cylinder head. Once I had got to the point where I knew that the design of the head would package and work within the Mini engine bay it was time to make the big decision:
Do I turn the intellectual exercise into a reality? Or leave it there. I know this may sound like there’s a lot of work to this point, why would I do this if I wasn’t planning to go all the way. Well the simple answer is that up until now I had not put a lot of cash into the project, to go to casting meant a commitment in money, with a chance of wasting a lot of cash that could be spent getting the 5 port going. But to be honest I had actually gone too far to back out and spend the rest of my life wondering…
During all the design process I had been planning how the head would be cast, there would be inlet and exhaust and water jacket cores. The outer mould would be made in three parts, a top, bottom and front piece. As I described earlier, I had modelled a machined head, now I had to re-model it with casting allowances included, as well as the feeder and vents. Casting allowance is 5 mm for all machined surfaces from this I could then model the cores and moulds directly.
That’s right I would model the moulds, no patterns would be made, yes you read that right I did not make patterns. Instead I had the moulds 3D printed in sand… This is one of the ways I kept costs reasonable and kept the pace up. There are a number of advantages to using this technique:
• It’s quick
• It’s very accurate
• Very reasonable price for one off and small volumes
• You don’t have to worry about draft angles and over hangs (indeed the water jacket would be very impossible to make in a single core box)
• It’s seriously cool!
Before I committed to this, I did 3D print a 40% model which I took to the foundry to discuss with the casting gurus there. This was very fortunate as I found that I couldn’t assemble the exhaust core through the water jacket core as I had thought I could. Result was I had to cut the water jacket into 2 pieces. Doh! Has to be said the foundry guys were awesome, spending time to help me and show me around, there wasn’t any issues with helping one dude with a single casting. And their Guru had been casting longer than I have been alive (and I’m 51).
Once I had the OK from them, I went to CSIRO in East Melbourne and they printed my first set of moulds. Again they couldn’t have been more helpful.
To explain these images, the head is cast upside down, however the mould is also assembled upside down… Normally the foundry wouldn’t do this as they don’t like to turn finished moulds over but as this was only a small one they were OK with it (They showed me a flywheel they had just cast at over a tonne, so an 18Kg casting is tiny!)
I haven’t got any images of the thermostat housing or inlet manifold moulds, they were simple 2 piece moulds, with one core…
Once printed I took them to the foundry who cast them:
If you look at the top (bottom) face of the head casting you can see it’s a bit rough, this was the only area of concern, the rest of the casting was perfect. I can tell you this was a tense time for me, once I had the casting though I was on a bit of a high for a few days. I wanted to have 2 initial heads cast so after the first success I added an extra 3 mm. of allowance onto the top of the casting due to the rough surface being a bit of a worry and had a second mould made.
This casting blew big time, I ended up with a huge hole in the middle. This was probably the lowest time during the whole thing, and I nearly threw the towel in. However I cut it up with an angle grinder and found an issue… When I added the 3mm of extra allowance I had to update the water jacket design to match… I had the wrong water jacket! This meant that it was not touching the top of the mould so couldn’t vent properly, I now knew why the casting had blown! The printers printed me a new set of moulds and the foundry made the casting, as slowly as possible to aid venting. This third casting looks perfect, I havn’t had any machining done on it yet though…
It’s off to machining now, but that’s another Chapter!
Top
 Profile
PostPosted: Wed Jan 29, 2020 1:54 am
Offline
And a couple more images cos I can only add 5 per post!
Top
 Profile
PostPosted: Wed Jan 29, 2020 1:58 am
Offline
Costafortune wrote:
Superb work.
You'd need:
Loom
Throttle body
ECU
Crank pulley
Air flow meter/MAF
Coil pack and leads
Coolant temp sensor
I am using a Megasquirt, but this is useful info thanks.
Top
 Profile
PostPosted: Wed Jan 29, 2020 8:33 am
Offline
Can i be very rude an ask how much it cost to have them cast ?
Its just out of interest, as i have no idea
So no if you prefer :D
Top
 Profile
PostPosted: Wed Jan 29, 2020 9:20 am
Offline
Another great post, thanks Trog!
I reckon I am fairly clued up on techniques for making small batch stuff happen, but I had no idea you could get moulds printed directly! Cwertainly a MUCH better option than making patterns which are always time consuming & expensive. It's certainly something I'd like to look into in the future.
Thank again for this latest thrilling instalment. I can't wait for the next one.
_________________
Top
 Profile
PostPosted: Wed Jan 29, 2020 10:20 am
Offline
Nor did I. That's an amazing bit of kit. Imagine that linked up to our 3D scanning tech.
I'm off to tell our casting technicians! Can you imagine the fun the students (of course, as ever, I'm only thinking of them.....) could have with that?
Al
Top
 Profile
Who is online
Users browsing this forum: steve and 15 guests
Search for:
Jump to:
