mk1-forum.net
It is currently Wed Feb 19, 2020 1:31 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Author Message
PostPosted: Mon Jul 22, 2019 5:18 pm
Offline
Yes please
Top
 Profile
PostPosted: Mon Jul 22, 2019 10:38 pm
Offline
Top
 Profile
PostPosted: Tue Jul 23, 2019 12:01 pm
Offline
The protractor appears to show the cone angle at 30 degrees - unless that's something to do with the camera/photo. Just checked a couple of odd hydro bits here on my lathe cross head and they all show 45 degrees. Not something to loose sleep about I agree because so long as there is full leakfree contact, that's all that counts
I recall a 3-way discussion re the hydro end fitting, wondering if a simple brass or steel well fitting threaded sleeve couldn't be soft soldered onto the output nozzle of the hydro unit, as shown. Made from, say, 5/8" AF hex bar with a hex part at the base to aid tightening the new hose part. Soft solder or even an industrial grade 2 part adhesive.
Water in the bottom part of the bowl to prevent heat (only the melting point of soft solder don';t forget so hardly a problem I'd say) contaminating the rubber diaphragm and away you go. Simple. Makes you wonder why they didn't do it this way to start with.
An alternative thought was and adaptor fixed to the nozzle using compression fittings. After all, compression fittings are in regular use in machinery hydraulics and tank elevating mechanisms
Do you remember this discussion with the US based forumer Spider Chris?
Top
 Profile
PostPosted: Tue Jul 23, 2019 1:18 pm
Offline
Got the metric one today, similar to the one Andrew suggested. The thread is a good fit, better than the BSP, but not as good as the original. However the cone is still the problem, it's not a cone. It probably would seal, but only over a very small area. I'm wondering if I can get a JIC fitting and remove the UNF nut component(correct thread) and put it on a BSP cone(correct cone). If other aspects are compatible then I don't see why not. The original cone, at least from my hydro bags, is 30° but I think they refer to it as 60°, which is the BSP size.
Top
 Profile
PostPosted: Tue Jul 23, 2019 5:25 pm
Offline
At some point I will be looking into whether I can get a suitable ferrule to utilise the original coned insert, along with a new outer nut.
You are correct in that the seating surface area is quite small with the hose end I mention, and I believe is used but the rehosing outfit but it is enough to provide a good seal for the pressures involved.
Top
 Profile
PostPosted: Tue Jul 23, 2019 7:52 pm
Online
I’ve rescued the cone to seat seal by just lapping them in with grinding paste. It worked fine where I had a corroded seating. I don’t see why you couldn’t use this on new bits to widen the seat a little.
Top
 Profile
PostPosted: Thu Jul 25, 2019 5:37 am
Offline
In case it helps here's the hose section of the BMC Australia displacer engineering drawing.
Top
 Profile
PostPosted: Thu Jul 25, 2019 10:10 am
Offline
That's really interesting, thanks.
Top
 Profile
PostPosted: Thu Jul 25, 2019 10:16 am
Offline
That's definately confirmed the 60 degree cone and cup Winabbey. I wonder who might have the Dunlop GPO-42 fittings.
Added: Just been down and checked the angles of the cones and cups for the hydro joint bits I've got apart - just in case I was getting a bit innumerate or blind in my old age. Yep, against a lathe cross slide and engineers protractor......, all 45 degrees! Never say never when it comes to BMC!
Top
 Profile
PostPosted: Thu Jul 25, 2019 10:33 pm
Offline
I’ve got a rough as **** one you can section Peter. I’ll bring it when we next do coffee down south.
_________________
Top
 Profile
Who is online
Users browsing this forum: burchy35, Mikeyjim, Old English White and 20 guests
Search for:
Jump to:
