mk1-forum.net
It is currently Fri Feb 21, 2020 1:35 am
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2, 3  Next
Author Message
 Post subject: Nuts n bolts
PostPosted: Tue May 21, 2019 11:02 pm
Offline
Another dull question. Rebuilding the car after a respray. So do you replace all the bolts with shiny new non original ones or put it back together with the old brown original ones :roll:
Don’t suppose you can get the same bolts with the tapered ends anymore?
Top
 Profile
 Post subject: Re: Nuts n bolts
PostPosted: Tue May 21, 2019 11:03 pm
Offline
You can get all your original bolts replated
Top
 Profile
PostPosted: Wed May 22, 2019 1:33 am
Offline
For me personally, using the old fittings or having them re-plated is taking originality too far. I prefer to use new silver zinc plated nuts, bolts, washers and spring washers which are readily available.
I do however break far far away from tradition by applying a dab of anti-seize so I can get the flippin' things undone again in the future!
Top
 Profile
PostPosted: Wed May 22, 2019 2:52 am
Offline
For all the internal and hidden stuff I always reuse the original bolts whenever possible. I find the quality is generally better than modern machining, and I have a “big bag o’ bolts” recovered from previous teardowns and scrappers which gets carried from one car to the next.
For visible things like the nuts on the thermostat housing I use stainless, for the ‘bling’ factor - nothing worse than seeing rusty bolts on a freshly restored engine... but then, i’m also ‘that ocd guy’ who tries to make sure the flats of the jubilee clips, nuts and bolt heads are all aligned in the same direction with fore-aft with the car...
Top
 Profile
PostPosted: Wed May 22, 2019 8:05 am
Offline
Location: Unquestioning tool of the much misunderstood Mysterons.
I can't see the point in using scanky old fixings. OK, you can get the originals replated, but how often do you remove a beautiful virgin bolt from a Mini? In my experience pretty much never! They are usually mashed up, rounded off have worn threads or whatever.
Thankfully good quality new BZP UNF fixings are easy to get hold of here & I have pretty much replaced everything as I have gone along for years.
All mechanical fixings are only as good as the thread / head they have & trying to reuse worn / damaged originals seems daft to me.
As with everything else, there is no right or wrong answer, but personally I like to work with clean 100% new fastners wherever possible. I do however make sure that they are the correct type & spec for whatever they are being used for.
_________________
Forum founder, backer & only admin for nearly 20 years.
I Must be f*&%^g mad
Top
 Profile
PostPosted: Wed May 22, 2019 9:16 am
Offline
I'm firmly in the Minibitz and Mk1 camp here. Always use readily available new with plenty of coppaslip.
Top
 Profile
PostPosted: Wed May 22, 2019 10:10 am
Offline
I also use mainly new fasteners and stainless where its suitable, catmint do a good rear subframe fixing kit in stainless with correct tapered bolts.
Top
 Profile
PostPosted: Wed May 22, 2019 10:39 am
Offline
I use new BZP mild steel nuts, bolts, washers as much as possible.
The only things I use originals on are the threaded screws for trim parts, speedo housing, door hinges etc etc as the modern offerings are not right.
Top
 Profile
PostPosted: Wed May 22, 2019 11:54 am
Offline
Catmint was a good shout. Cheers lads
Top
 Profile
PostPosted: Wed May 22, 2019 12:59 pm
Offline
I have a large drum type rock polisher. Every nut, bolt and washer goes in for a cleaning followed by a quick inspection. Questionable parts go directly into recycle bin. The balance is wire brushed sprayed with WD40 and sorted by size length and thread. Stored in clear plastic well marked containers. I also buy a lot of new SAE grade nut ,bolts and washers. All race car projects get new grade 8 or better. Steve (CTR)
Top
 Profile
Who is online
Users browsing this forum: No registered users and 18 guests
Search for:
Jump to:
