mk1-forum.net
It is currently Fri Feb 21, 2020 1:05 am
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Author Message
 Post subject: Re: Mini Spares
PostPosted: Sat May 18, 2019 12:07 am
Offline
Although I've had my first order confirmation email I've not had a dispatched follow up yet, I'm sure they are working as hard as they can to resolve issues, we are all very dependant on computer systems these days and when something happens it always takes time to unravel the mess.
Top
 Profile
PostPosted: Sun May 19, 2019 11:48 pm
Offline
Sounds like Mini Spares might have a handle on the problem. A phone call revealed that my order had been shipped and tracking showed it to have arrived in the US. Now if only the USPS can manage to get it out of San Francisco enroute to Tacoma......Congrats to Mini Spares for all of the hard work.
Top
 Profile
PostPosted: Mon May 20, 2019 7:00 am
Offline
The dispatch email has arrived parts on the way 8-)
Top
 Profile
PostPosted: Sat May 25, 2019 11:19 am
Offline
Well done Minispares, ordered on Thursday 23rd arrived Friday 24th. You can't get much better than that, unless you could come and fit the parts.
Top
 Profile
PostPosted: Sun May 26, 2019 12:35 am
Offline
Yes , l emailed them about a new flywheel l had bought from them that failed and never got a reply :( , a supposedly EN24 flywheel the boss stretched alowing it to move forward thus jamming the primary gear .
Top
 Profile
PostPosted: Tue May 28, 2019 9:24 am
Offline
Location: Unquestioning tool of the much misunderstood Mysterons.
Very, very unlikely that it "stretched".
As Minispares sell literally 100's of these a year it is unlikely that the one you bought is suffering a unique problem. Probably best to pursue them direct.
_________________
Forum founder, backer & only admin for nearly 20 years.
I Must be f*&%^g mad
Top
 Profile
PostPosted: Tue May 28, 2019 4:40 pm
Offline
As Minispares sell literally 100's of these a year it is unlikely that the one you bought is suffering a unique problem. Probably best the pursue them direct.
Take it from me number 1 , it stretttttttched , moved forwards on the nose of the crankshaft and jammed the primary gear which meant of course that l could not work the clutch and thus not drive the car, and yes there was clearance when l assembled it all on the stand . After l stripped it again and re-fitted the flywheel and tightened it up you could actually hear the flywheel as it moved up the taper ...........l do my flywheels up to 160 foot lb plus . l'm not bagging minispares , l've bought thousands of pounds worth of bits n pieces off them over the last 8 years and their service and quality l have found to be excellent . l emailed them twice about flywheel but never recieved a reply so just gave up and bought a replacement one off MED.
Top
 Profile
PostPosted: Tue May 28, 2019 6:14 pm
Offline
I don't understand what you mean? When you add the primary gear thrust washer, fit the primary gear, primary gear backing ring and primary gear C ring and check the standard gap 4-6 thou for me, the flywheel will only meet the C ring & backing ring?
I'm lost here honest :?
Alan
Top
 Profile
PostPosted: Tue May 28, 2019 6:26 pm
Offline
Not sure it would stretch the flywheel, more likely the threads in the crank and bolt but the flywheel torque setting is 110-115 ft/lbs not 160+
Top
 Profile
PostPosted: Fri May 31, 2019 12:23 pm
Offline
Supersonic wrote:
minimad wrote:
mk1 wrote:
Very, very unlikely that it "stretched". ...
Take it from me number 1 , it stretttttttched , moved forwards on the nose of the crankshaft and jammed the primary gear ...
Alan
I suggest an alternate problem. If the bore of the new flywheel is not made to spec (just a few thousandths too large in diameter) then the flywheel will crawl too far forward on the crank tail. I agree that this probably won't jam the primary gear but it can cause the ring gear to contact the aluminum housing. This happened to my car years ago when a lot of lapping was done to clean up both the crank tail and the flywheel hub bore. I ended up needing a new flywheel hub to move the ring gear away from contact. Again, it didn't jam the primary gear but jammed the ring gear.
_________________
Doug L.
Top
 Profile
Who is online
Users browsing this forum: 1071bob, 850mini, MSN [Bot], Trog, wj33 and 12 guests
Search for:
Jump to:
