Fuel tank thingy
Re: Fuel tank thingy
PM sent Andy
winabbey
Post by winabbey »
AndyPen wrote:I don't suppose you fancy sending a few over for local distribution? Happy to sort this end and pay up front if needs be? I'd like 3 myself anyway if possible as all my cars should have this.
Happy to help. PM sent.
GraemeC
Post by GraemeC »
mk1 wrote:BUT in every example of these that I have come across, the bleed nipple is rusted hard into the bottom of the tank & access to it is so limited it is "almost" impossible to remove by the "standard" route.
In this case the only option in removing the tank is smashing the pipe off & ragging at the nipple until you can extricate the tank.
Ah - makes perfect sense when you explain it like that!
Thanks for the pms folks, we are making plans ;-)
Beatie
Post by Beatie »
Don’t suppose anyone knows but was the tube arrangement std to all mk1’s which had the drain facility?
Reason I ask is I have two 64 tanks both have a rusted in flat slotted screwdriver driven plug rusted into the brass bung.
Any thoughts anyone ?
Beatie wrote:Don’t suppose anyone knows but was the tube arrangement std to all mk1’s which had the drain facility?
One of my tanks has this too I now realise, and another very rusty one I never got to throw away appears to have a broken version.
Beatie
Post by Beatie »
Don’t suppose anyone knows the thread size ?
It looks like 3/8 ??
1071bob
Post by 1071bob »
Beatie wrote:Don’t suppose anyone knows the thread size ?
Yes, it's 3/8" UNF. Looking at my tank you have to wonder how long it would take to drain the fuel through an 1/8" diameter hole! Would be quicker to take the feed pipe off the carb and use the electric pump to drain it.
I have been thinking exactly the same ever since the thread started 1071Bob! Looks like one of these '.....it was a good idea at the time' jobbies. Until a bit of grot from the bottom of the tank drops down into the drain and......... Surely, this is one of those cases where it's more realistic to fake a look-a-like thinggy up. And if the tank does need emptying - as both mine did this Summer - just siphon (or is it syphon?) them with a bit of tube like everyone else does, syphoning the clag from the bottom of the tank as you go.
Beatie
Post by Beatie »
Cheers Bob
I’ve got to drill at least one of mine out as the steel plug has corroded so much , heated 4 times over the weekend and have ended up destroying what was left of the screwdriver slot .
Will try easy out next before drilling to core dia .
I do wonder whether the screwdriver slotted plug was a tech bulletin issued to dealers in the day as the pipe arrangement was fraught with many disasters?
