mk1-forum.net
It is currently Wed Jan 16, 2019 4:58 pm
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: Pedal box
PostPosted: Wed Jan 09, 2019 5:21 pm
Offline
Can any one tell me, the pedal box, is it painted black or should it be body colour? mine is black.
My shell will soon be going to paint and would like to know if i need to change the colour.
Top
 Profile
 Post subject: Re: Pedal box
PostPosted: Wed Jan 09, 2019 5:30 pm
Offline
Black
Top
 Profile
PostPosted: Thu Jan 10, 2019 10:57 am
Offline
jerry wrote:
Black
Yes, I have an old original here and it is satin black, with remnants of soundproofing material where it fits against the body shell ;-)
Top
 Profile
PostPosted: Thu Jan 10, 2019 6:11 pm
Offline
And very easy to rebuild/restore when it's out and on the bench. Make sure that your strip, clean and grease up the pivot points of the pedals before you assemble it New bushes for thepedals are available if the pedals are a sloppy fit on the axis pin. And make sure that if the holes for the brake and clutch clevis pins in the pedals are not even slightly oval before you reassemble it. If so, fix them before you put it back.
When you assemble it to the car, might I suggest that you disconnect the pedal actuating spring from the pedals, THEN assemble it to the car, THEN connect the clutch and brake push rod, THEN hook the actuating spring behind the pedals. Just done it!!!!!
Top
 Profile
Who is online
Users browsing this forum: Exminiman, morris cooper, STG95F and 24 guests
Search for:
Jump to:
Localized by MaĆ«l Soucaze © 2010 phpBB.fr
