Help with cleaning door cards
360gts
Post by 360gts »
Suggestions welcome on how to save this front Dove grey door card. It is covered in old contact cement....some idiot decided to glue something on the door cards.....
Wait to hear if anyone has a good solution before I use something that will destroy it.
If I can get it cleaned up good enough for a respray.....will be happy with that.
Attaching a picture of a front speedo piece that was Cumulus Grey,,,had some vinyl paint mixed to match some NOS Dove grey.....
Pretty darn good match.
iain1967s
Re: Help with cleaning door cards
Post by iain1967s »
Most glues will dissolve with acetone, but vinyl being oil based will also dry out and crack quickly. I’d say acetone on q-tips or kitchen roll for the surface cleaning (don’t let it soak in!) and then as soon as the gunk is off, spray it down with a vinyl protector such as Vinylex or ArmorAll wipes.
cpr1
Post by cpr1 »
Don't laugh , if it's old contact adhesive, rubbing it with your fingers, it will come off , but your hands will require some TLC afterwards! :lol: or maybe a rubber eraser will do the trick also had some brocade cleaned this way as it was used as a roof lining on a small van . I think if you try cleaning it with solvents will make it worse.
Dearg1275
Post by Dearg1275 »
If you give it a good scrub with a nail brush and warm soapy water it can be quite surprising sometimes what comes off.
Gray
Post by Gray »
Try some brake cleaner on a cloth Dermott I have found this quite good on a lot of sticky residue however have not tried it on contact adhesive the good thing is it evaporates before it can do any harm.
mini_surfari
Post by mini_surfari »
no that I've tried it on upholstery nor paint... but on glass i always use bufsol to remove glue/ residue
360gts
Post by 360gts »
Got most of the dried cement off....tried the brake cleaner.....did help a bit...the vinyl is stained from the contact cement. Leaving it overnight to dry well...will give it a coat of the vinyl spray I had mixed....think it will be fine. Will post a picture after it is painted.
360gts
Post by 360gts »
Still working on the door cards...got the rears complete......hours of cleaning....then, give the card backing a soaking with warm water, Laid flat on the floor with a board on top with heavy weights. Two days later...the cards are perfectly flat as they once were. A coat of the
Dove grey vinyl paint and here is the finished product.
Had to do a little trimming on a couple of the corners as the backing was damaged.
Dove gray paint and here we are.
360gts wrote:Still working on the door cards...got the rears complete......hours of cleaning....then, give the card backing a soaking with warm water, Laid flat on the floor with a board on top with heavy weights. Two days later...the cards are perfectly flat as they once were. A coat of the Had to do a little trimming on a couple of the corners as the backing was damaged.
Patience is indeed a virtue on jobs like this - well done ;-)
Dearg1275
Post by Dearg1275 »
That seems to have come out with the right degree of sheen. What product did you use? I have had trouble with a vinyl dye coming out far too glossy.
