mk1-forum.net
It is currently Wed Mar 27, 2019 3:19 am
Post new topic Reply to topic  [ 9 posts ]
Author Message
 Post subject: Value of......
PostPosted: Fri Oct 05, 2018 1:15 pm
Offline
Suggestions please, what’s the going rate for a very good condition, set of four AEG177 sprite rods :?:
Top
 Profile
 Post subject: Re: Value of......
PostPosted: Fri Oct 05, 2018 1:59 pm
Offline
£150 - £200 depending on condition.
New steel ones start at about £250
_________________
(John, This is a JOKE Telephone number, it doesn't work)
Top
 Profile
PostPosted: Fri Oct 05, 2018 2:23 pm
Offline
Thanks Mark.
Top
 Profile
PostPosted: Fri Jan 11, 2019 10:54 am
Offline
I have another one....
What’s the going rate, value, for a 1300gt bare block, with caps :?:
I’ve been offered a block that had been freshly bored to 73.5mm (which is the size I’m looking to build) and was fitted into a vehicle to be run in. It was at 1100 to 1200 miles in, when it had a gearbox mainshaft bearing fail. The block was stripped and checked for damage, and was found to have no damage to the cylinder bores.
So sure it needs new cam bearings, a flush of oil ways, some new core plugs ect, and a good check over at the machine shop. This engine was built in the late 80’s for rally use. It has been dry stored since. I’ve had a look over it and it looks perfect to my untrained, numptys eyes.
I’d like some advice please.
Top
 Profile
PostPosted: Fri Jan 11, 2019 11:22 am
Offline
£150 Max
_________________
Top
 Profile
PostPosted: Fri Jan 11, 2019 1:45 pm
Offline
If it is a bare block, do you know what pistons it was bored for?
Top
 Profile
PostPosted: Fri Jan 11, 2019 2:30 pm
Offline
I thought that too, but didn't want to get to analytical about it.
_________________
Top
 Profile
PostPosted: Fri Jan 11, 2019 4:17 pm
Offline
As stated I’m a numpty,
The story is, it was a 1380cc build, bored to 73.5mm.
All I have done is just looked over it and dropped a vernier calliper in the top of the bores and it measured 73.5m just as he said it was. That’s as much as I’ve done.
I don’t know what Pistons it was using?
Top
 Profile
PostPosted: Fri Jan 11, 2019 4:18 pm
Offline
1300GT blocks will have the big casting hole above the centre main. The Allegro blocks didn't, and you can easily drill and tap the extra 2 holes.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 19 guests
Search for:
Jump to:
