MK2 rear quarter window frame rivets
General Chat with an emphasis on BMC Minis & Other iconic cars of the 1960's. Includes information on MK1 Action days.
360gts
Post by 360gts »
I know there is a thread on this subject...just cannot find it.
I had posted about these rivets and screws that are used on the MK2 style rear quarter windows.
Have not been able to source the screws but I have found the exact rivets. Luckily, have some good screws from a couple of old frames.
Just completed the restoration of my late 67 S windows. I used a bicycle inner tube for a gasket...worked perfectly. Here are some pictures of the rivets...the finished product and source information.
Source for the rivets.....https://www.ebay.co.uk/itm/25-STAINLESS ... %7Ciid%3A1
Inner tube is on the attached picture. Need one tube for each window...cost about $6.50 each.....just cut it up the center and inserted into the frame. After the frame is screwed back together..... trimmed off the excess rubber.
Prefer this approach as the replacement rubbers are extremely difficult to get into the frames...especially where the hinges are fitted.
Used extra fine wet and dry and finished off with Autsol polish.
Very happy with the outcome.
AndyPen
Re: MK2 rear quarter window frame rivets
Post by AndyPen »
To be fair they look great ;-)
swindrum
Post by swindrum »
If you want to save a few bucks, go to any bicycle store, I wager they will give you as many old tubes as you need!
Nicely done
360gts
Post by 360gts »
swindrum wrote:If you want to save a few bucks, go to any bicycle store, I wager they will give you as many old tubes as you need!
Nicely done
Thanks...I did go to a bike store...the really thin inners are more $$ than regular tubes....still....not bad $13.00 for both windows as Somerford charge 8.50 pounds per rubber.
Fanfaniracing
Post by Fanfaniracing »
Nice to know! Did you put any lubrificant or powder on the rubber when you fited the
glas? Or does it go inside the frame easy?
Brian Thurston
Post by Brian Thurston »
I also have had a few good screws on some old frames!
