mk1-forum.net
It is currently Sat Feb 16, 2019 9:12 am
Post new topic Reply to topic  [ 9 posts ]
Author Message
 Post subject: Bestest Battery?
PostPosted: Sun May 20, 2018 10:12 am
Offline
Morning chaps. Hoping to finish my 65 1275 S THIS summer! :lol: Can anyone recommend a very good battery for it---std'ish compression and electrics, +earth with a dynamo and will only be used w'ends and holidays. Many thanks. Cheers Ray.
Top
 Profile
 Post subject: Re: Bestest Battery?
PostPosted: Sun May 20, 2018 2:32 pm
Offline
VARTA........., but! Make sure that when it's not being used that it's on a very low charge trickle charger, timed to come on for a few hours every day. Just my opinion of course based on my experience with looooooong lasting Vartas in mine
Top
 Profile
PostPosted: Sun May 20, 2018 5:28 pm
Offline
...always used Unipart on mine.. plus a Halfords trickle charger ... best 30 plus quid any classic mini owner could treat their mini to.. always started first time in minus temps on a sunny winters day before a drive ... foxy52
Top
 Profile
PostPosted: Sun May 20, 2018 6:04 pm
Offline
+1 on connecting the battery to a minder of some sort when the car sits more than a few days.
I've been using a CTEK charger/conditioner/minder unit along with a 'comfort connect' lead for the past few years. It has kept one battery tip-top for over 5 years (in 2 separate Minis) and gets used on another vehicle we have that sits at times as well. Unreservedly recommend their products.
Top
 Profile
PostPosted: Sun May 20, 2018 7:42 pm
Offline
Another for the ctek charger...just comes on a timer for an hour once a week...no problem
Can also recommend Varta..used one very successfully on an mpi
_________________
Kevin
Top
 Profile
PostPosted: Sun May 20, 2018 11:37 pm
Offline
Many Many thanks Peter,Foxy,Bertam+Kevin.
Will look into that.......which model number should I look for i.e does size matter?!?! :roll:
Top
 Profile
PostPosted: Mon May 21, 2018 6:23 am
Offline
My car has had a cheap small 043 battery (260CCA) in it for over 5 years. It always cranks the car over fine, and it's survived going flat at least once when the alternator died.
Over here we can get 058 and 067 size batteries which also fit in the box, you'll have to make sure the terminals suit + earth. Any decent battery shop should be able to sort you out, or you can search for the dimensions on a site like this:
https://www.tayna.co.uk
You don't necessarily need a huge battery if you keep it on the trickle charger or use it often enough to keep the battery charged.
Top
 Profile
PostPosted: Mon May 21, 2018 1:26 pm
Offline
If you have a RH tank you may want to consider a battery with the terminals on the LH side. With the standard terminal arrangement I wasn't comfortable with how close they were to the tank..
Top
 Profile
PostPosted: Mon May 21, 2018 10:05 pm
Offline
Ah yes...... it does have a RHT. Will bear that in mind. Thanks.
Top
 Profile
Who is online
Users browsing this forum: rnp68 and 21 guests
Search for:
Jump to:
Localized by MaĆ«l Soucaze © 2010 phpBB.fr
