mk1-forum.net
It is currently Mon Apr 22, 2019 9:21 am
Post new topic Reply to topic  [ 12 posts ]  Go to page 1, 2  Next
Author Message
 Post subject: HELP NEEDED
PostPosted: Mon Apr 16, 2018 8:20 pm
Offline
after some help/ suggestions, can anyone solve this problem on 1964 mk 1. the offside handbrake cable has decided to touch the inside wall of tyre, tyre is strait. nearside cable is about half inch away. all bearings on the radius appear to be ok, i e no play.no apparent damage to be seen, at loss with this .anything else, help mot due soon, thanks steve
Top
 Profile
 Post subject: Re: HELP NEEDED
PostPosted: Mon Apr 16, 2018 8:33 pm
Offline
Is it hydro
Top
 Profile
PostPosted: Mon Apr 16, 2018 9:13 pm
Offline
standard ,never had the problem before, now classed as failed mot
Top
 Profile
PostPosted: Mon Apr 16, 2018 9:17 pm
Offline
Can you post some pictures?
Top
 Profile
PostPosted: Mon Apr 16, 2018 9:52 pm
Offline
Add a thin spacer each side? Was a BMC mod at one stage to clear the shockers.
Top
 Profile
PostPosted: Tue Apr 17, 2018 1:26 pm
Offline
Or space the hand brake bracket in a bit until the cable clears.
Top
 Profile
PostPosted: Tue Apr 17, 2018 1:36 pm
Offline
I would do as is suggested above, space the hand brake cable holder off the back plate a bit using spacers & longer bolts.
_________________
(John, This is a JOKE Telephone number, it doesn't work)
Top
 Profile
PostPosted: Tue Apr 17, 2018 2:17 pm
Offline
bent radius arm / spindle ?.........
_________________
Top
 Profile
PostPosted: Tue Apr 17, 2018 6:38 pm
Offline
Yes. I did just this, bounced a rear wheel off a kerb at speed and bent the radius arm.
Top
 Profile
PostPosted: Tue Apr 17, 2018 8:24 pm
Offline
thanks for the comments, have sorted ,due retest Wednesday. handbrake rear bracket replaced with a 61 spare-slightly bigger clearance pushing cable away from wheel, plus added couple washers helped . finally added a couple of washers to the inside of the wheel to face of the drum. this has given sufficient clearance, but the initial cause is still a mystery. cheers steve :D
Top
 Profile
Who is online
Users browsing this forum: Google [Bot], Peter1071 and 18 guests
Search for:
Jump to:
