mk1-forum.net
It is currently Sun Dec 16, 2018 9:31 pm
Post new topic Reply to topic  [ 10 posts ]
Author Message
 Post subject: Alloy Wheel Nuts
PostPosted: Tue Dec 05, 2017 2:07 am
Offline
Hi All,
I'm looking for a set of shank/sleeve type wheel nuts for a set of wheels I've bought recently. I'm wondering if anyone knows of an off the shelf solution that'll work before I get the wheels modified to fit the nuts I can find..
Wheel hole diameter is 9/16" (0.5625" or 14.3mm)
Rim face thickness is 1" (25mm)
If I can't find a set that'll work I'll probably get the holes taken out to 5/8 or 11/16 as I can find nuts to match that size locally.
And a photo of the wheels:
Cheers, Tim
Top
 Profile
 Post subject: Re: Alloy Wheel Nuts
PostPosted: Tue Dec 05, 2017 2:14 am
Offline
I just picked up a set of these based on recommendations from an MG board - quality seems good. His listing says he ships worldwide: https://www.ebay.com/itm/16-MAG-LUG-NUT ... 4670d855f2
_________________
-Andrew
My 1964 Mk1 Traveller
My 1964 Mk2 Sprite
Top
 Profile
PostPosted: Tue Dec 05, 2017 10:06 am
Offline
The one stop solution for all wheel nut related problems.
http://www.speedshack.co.uk/Wheelnuts.htm
The details have been added to the Reccommended suppliers section.
_________________
Top
 Profile
PostPosted: Tue Dec 05, 2017 11:11 am
Offline
Totally agree with Mk1 above. You could make yourself a set to suit using your wheel as the 'negative' for the exact configuration but make sure that any angles are an exact match for good sound mechanical reasons. Having made myself a set of (stainless) nuts for a set of alloys. I can tell you it's a pain in the axxe compared with buying a CNC turned set of ready mades from Mk1's suggested supplier.. If your wheels aren't known to him, he might ask for a sample or a perfect drawing.
To be honest, the wheel on the floor looks better than the one you're putting on!
Pete the Pom
Top
 Profile
PostPosted: Wed Dec 06, 2017 12:33 am
Offline
Thanks, those ones look to be too large to fit through the wheels as they are.
Thanks, I've sent them an email to see what they have
Pete the Pom
I was looking/hoping for an off the shelf solution if possible for the moment. The old wheels are also the most common set of mini alloy wheels in Aus and I fancied something different :mrgreen:
Top
 Profile
PostPosted: Wed Dec 06, 2017 9:04 am
Offline
Great looking wheel and very different to the usual Rosepetals and Minilites.
I have seen them before but had forgotten about them until just now. Might have to look out for a set myself.
Good luck with your nuts
_________________
Rolesyboy
Top
 Profile
PostPosted: Wed Dec 06, 2017 9:38 am
Offline
Amos Rims cast in Brisbane Australia. I think you and I are amongst the few people that have a set. I am lucky to have 5 :D
Top
 Profile
PostPosted: Wed Dec 06, 2017 9:41 am
Offline
Speedshack can supply a huge variety of nuts from stock.
_________________
Top
 Profile
PostPosted: Wed Dec 06, 2017 10:34 am
Offline
Look on UK ebay no; 1624076528 the engineering company Illson & Robson have 14mm od dia; shank wheel nuts that they call Jelly Bean .. when i was there he told me they were for Australian Wheels.
If you have total failure i have available a set of GKN Silverstone wheel "Nuts & Washers" that will fit your wheels .. but only IF you machine down to reduce the outside dia; of the nut spigot.
Top
 Profile
PostPosted: Thu Dec 07, 2017 3:35 am
Offline
You might have a tricky time finding these wheels, there were also a similar type made in Sweden by JP wheels.
I'm guessing you bought the set Matt Read had a couple of years ago? Have you ever had them installed on a car, I'd be interested in seeing what they look like
I'm waiting to hear back on what they can supply for me
Thanks, I've had a look at them and they are Jelly bean and Contessa type wheel nuts. The Contessa alloys are on the car at the moment so I have a set like that already. As the face of these wheels is a bit thicker I don't think I'm getting enough thread engagement to safely hold them on.
Top
 Profile
Who is online
Users browsing this forum: Bing [Bot] and 17 guests
Search for:
Jump to:
Localized by MaĆ«l Soucaze © 2010 phpBB.fr
