mk1-forum.net
It is currently Sun Jun 24, 2018 3:41 pm
Post new topic Reply to topic  [ 13 posts ]  Go to page 1, 2  Next
Author Message
PostPosted: Sun Nov 05, 2017 4:41 pm
Offline
Just need a bit of clarification on acouple of topics if anyone can spare the time
I have looked in depth at the relvant regulations but still not convinced I have the correct interpretation.
1.
Can an A+ block WFN 1024 be used in either FIA AppK or HSCC Class D (or any other pre'66 racing)?
2.
I have a Mk1 Cooper S shell which came with a full bolt-in cage already fitted Front and Rear with a door bar on the drivers side. It is all correctly constucted and is the correct material dimensions according to the current MSA ROPS specification. However there are no makers marks of any description, I was told that it was fitted originally in around 1990+ . It is very well made and appears to be a 'professional' manufacturer produced item I would be happy to use it myself and I am very very careful about safety items.
Where do I stand regarding eligibility under current regulations?
3.
Finally what type of carburation is being usually used by Class D cars >1300cc at the moment ?
Any advice or clarification would be appreciated
Thanks trevor
_________________
Top
 Profile
PostPosted: Sun Nov 05, 2017 7:04 pm
Offline
Trevor
1. Yes an a plus block can be used in hscc class d. Not in app k though.
2. The cage is old so look at the feet. If only 2 bolts on the rear most legs then it's not legal. On older cages the feet are smaller and the stuff the cage is made is smaller. If no stickers on it it's easier just to buy a compliant cage.
3. Twin h4. You cannot cut the bulkhead so you will have to make a mess of it if you wish to fit webers. And for little gain.
_________________
Top
 Profile
PostPosted: Sun Nov 05, 2017 7:09 pm
Offline
Thanks Rich
The cage has 4 bolts on all of the feet and the tubing is 38mm o/d at 3mm thick
Shame there is no makers label or markings
Trevor
_________________
Top
 Profile
PostPosted: Sun Nov 05, 2017 7:10 pm
Offline
4 bolts on the feet that go onto the rear arches or the ones on the floor?
_________________
Top
 Profile
PostPosted: Sun Nov 05, 2017 7:14 pm
Offline
all the plates have 4 holes
_________________
Top
 Profile
PostPosted: Sun Nov 05, 2017 7:20 pm
Offline
Check the feet for letters and numbers stamped in.
Top
 Profile
PostPosted: Sun Nov 05, 2017 7:21 pm
Offline
ok will do thanks
Trevor
_________________
Top
 Profile
PostPosted: Sun Nov 05, 2017 8:03 pm
Offline
if the main feet have four holes, then its an early cage that is no longer msa compliant
the modern cages have three holes (that take three bolts) on the back arches, the four main feet have six holes (that take five bolts)
I've never seen a safety devices / roll centre cage that had four holes on the arch legs, so wonder if its a home made job?
the modern safety device cages have numbers stamped into the feet, but not all old cages do
a customer of mine has recently had to re-cage his rally car as the cage that was in it wasn't msa compliant and he commented that the old cage was noticeably lighter than the new one!
_________________
Top
 Profile
PostPosted: Sun Nov 12, 2017 1:09 pm
Offline
Finally got back from travels to check the rollcage....bit of a long distance communications malfunction
There are 4 holes in the back wheel arch legs 2 in each side Hmmmshould have asked s clearer question apparently ????
So it’s just a track day cage now
It is well made and is all the correct dimensions tube diameter and slightly thicker than required
I will buy the safety devices complete cage for this project
One last question for clarification
Can any pre ‘66 shell be used in class D and or AppK ?
That is can a pre 66 850 registered shell be used in 1293 form or does it have to be registered as a Cooper S etc
Final thought does the car have to have a registration to compete in Class D ?
I know it does for FIA AppK
Any information gratefully received
Thanks Trevor
_________________
Top
 Profile
PostPosted: Mon Nov 13, 2017 2:10 am
Offline
Thanks Trevor
Any Mk1 shell (not just pree '66) can be used with any pre '66 Mini logbook, doesn't have to be Cooper S.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 15 guests
Search for:
Jump to:
