mk1-forum.net
It is currently Mon Jun 17, 2019 5:50 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Author Message
 Post subject: Re: Rear radius arms
PostPosted: Fri Oct 27, 2017 5:11 pm
Offline
Peter Laidler wrote:
Thgat's interesting dearg. Quite how on earth they broke - presumably sheared - the almost 1" dia shafts is anyones guess, even if it was mild steel!!!!!
Peter,
The outer support brackets also received attention. These were double plated. The standard ones just couldn't take the punishment. To me this suggests that the shaft failure was probably at the threaded outer end. Using a none drilled shaft would surely have increased the reliability of this portion of the shaft.
David
Top
 Profile
PostPosted: Fri Oct 27, 2017 7:36 pm
Offline
Dearg1275, it sounds like the outer end was breaking?
Can't say I've heard of that, but I'm sure if it could be broken, those guys did break them :o
The Inboard ends do break off, not the main part of the shaft, but near the shoulder where the dia is reduced for the threaded end.
This in part, is why the shafts can't be hardened through.
I'll post up a photo shortly.
Top
 Profile
PostPosted: Fri Oct 27, 2017 9:42 pm
Offline
Spider,
Your reference to the inner threaded end breaking concerns me. If the proposal is to drill this end and supply grease to the inner needle roller this way, is that not weakening the threaded end? The works team were clearly moving away from the central drilling to gain reliability under extreme conditions. If it is only a matter of reducing wear and extending the life of the shaft/bearing then it is probably not a problem but it may be a problem if subject to constant extreme use.
Top
 Profile
PostPosted: Fri Oct 27, 2017 10:04 pm
Offline
I wouldn't let it concern you too greatly Dearg. It's like pretty much everything in the mechanical world - and not just the mechanical world either - . It is the best compromise between several things. While I don't have the facilities to shear load to bend or fracture a shaft at the start of the threaded end (is it 9/16"?, ain't got one handy.....) any more, you can imagine the tonnage required. And even a met. lab test like that is not a true or realistic trial of what the car might be subject to. More to it than that of course..., inertia and all that stuff. And think about it......, the other end has been bored across that point with a thin hole since pontius was a pilot
Top
 Profile
PostPosted: Sat Oct 28, 2017 12:48 am
Offline
Drilling a small hole through it for grease won't weaken by anything that matters.
Here's a couple from the collection, caught just before they broke off
Peter, the ends are 1/2"
Top
 Profile
PostPosted: Sat Oct 28, 2017 11:13 am
Offline
That's a classic Spider........ what careful tech authors would call '...point of commencement to crack' instead of just saying it as it is!
The interesting point to me is that it's bent/cracked at the reduction point but also bent at the start of the thread, as if to return the threaded part to parallel with the main shaft. You can imaging the shear loading at that point to make that happen - but it didn't shear. I wonder if a radius at the arrow/crack point would prevent this. After all, that's standard good engineering practice AND the thrust washers are actually countersunk at that point as if to allow for this. But while it's a good discussion point, it's beyond the scope of our rebuild. Food for thought is anyone was making new high quality shafts for hard use
Top
 Profile
PostPosted: Sat Oct 28, 2017 12:01 pm
Offline
Cheers Peter.
I don't tend to mince words in the way some authors write volumes, when one can just say 'It's a poor design' or what ever.
I did say 'caught' with the two that I've posted up here. By Caught, I meant caught them just before they did shear and yes they do. I'll see if I can find the photo,,,
Tonnes of force needed to do this yes, absolutely. In this regards, I'll point out / remind you that the rear swing arm is on a 5:1 ratio to the rubber cone and it's all via these pins.
Put 200 kg in the back (2 fat birds as they say) and that's 100 kg on each pin + the static weight of the car. So there's 500 kG + static. Then drive on the wonderful roads that are about & refer back to those graphs I posted a few weeks back and it does well get in to many tonnes. If you were to also add to that lowered shocks, when the rubber cones bottom out on the subframe, it gets well in to the 10's of tonnes.
As you've noted from the double bend, it is clearing a shearing action.
The Pins I've made I put a 0.020" radius in to them and I've found that quite adequate.
<Edit: Sorry it's not the best photo (not mine and part of a bigger photo)
Image >
Top
 Profile
PostPosted: Sun Oct 29, 2017 2:53 am
Offline
I broke a pin in a the Moke once, but it took three, not two, and a very large pothole.
Tim
_________________
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
Top
 Profile
PostPosted: Sun Oct 29, 2017 6:35 pm
Offline
You nailed it Tim and Spider. I bet there's a few civil engineer types reading this and recalling their student notes regarding levers and fulcrums - and clock/anti clock moments about an axis. This thread and subject are great (if nerdy.....) examples of the fulcrum point changing when the car hits the deck hard and it suddenly switches. If I was still teaching I'd be using this as one of those good everyday examples.
Top
 Profile
PostPosted: Sun Oct 29, 2017 11:41 pm
Offline
The trailing arm in the moke is a couple of inches longer than a Mini one, so I assume that increases the leverage on the pin when the three chicks drop into the pothole.
Tim
_________________
1955 BSA C11G
1969 Triumph TR6R
Top
 Profile
Who is online
Users browsing this forum: 5portsrock, johnv and 14 guests
Search for:
Jump to:
