mk1-forum.net
It is currently Fri Sep 21, 2018 8:39 am
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4, 5
Author Message
 Post subject: Re: Rear radius arms
PostPosted: Mon Oct 30, 2017 2:09 am
Offline
Tim wrote:
The trailing arm in the moke is a couple of inches longer than a Mini one, so I assume that increases the leverage on the pin when the three chicks drop into the pothole.
They are the same ratio.
Top
 Profile
PostPosted: Thu Nov 09, 2017 11:33 am
Offline
Here's something to make you all cheer. You know how we all go on about crap modern replacement parts? Well, stop there. Got a set of rear radius arm shafts from Rich at Mini Spares earlier this week and was at the Uni metallurgy labs to modify the lubrication system for our winter technical write up. After much spot facing, drilling attempts, more spot facing and grinding etc etc etc we eventually broke through the hardening into material that we could drill into with centre drill cutters. The depth of the hardness was .022" So just remember this when anyone tells you that the modern shafts are crap. Ruined several cutters and took a long time to just drill 2 cross holes in 1 shaft. The lab tech has banned us from the workshop for a week while he gets the blunted tools re-ground!!!
Sorry for complaining Rich!
And while we're here....... Can anyone see any reason why the inner shaft nut FNZ-508 and spring washer LWZ-208 shouldn't/couldn't be a nylock nut and flat washer
Top
 Profile
PostPosted: Thu Nov 09, 2017 11:53 am
Offline
how do you get it undone in service?
_________________
'long beard boss'
Top
 Profile
PostPosted: Thu Nov 09, 2017 12:01 pm
Offline
Easy!
When the radius arm is rusted solid into the radius arm it will hold the shaft firm & the nylock can be undone without any bother :lol:
_________________
Top
 Profile
PostPosted: Thu Nov 09, 2017 12:42 pm
Offline
that's why BMC made them the way they did you see.
they knew that by the time it came to take them to bits the rust would be providing a vital part of the undoing sequence.
by removing the rust and replacing it with grease the job becomes far harder to do!
_________________
'long beard boss'
Top
 Profile
PostPosted: Thu Nov 09, 2017 3:57 pm
Offline
There's a serious side to this of course...... How did we undo the bluddy things with normal nuts and spring washers? Let me think about this............ IF I had rusty or sticky nuts I'd go to the chemist first...... Just joking... By definition, the nut on one side or the other would have to come apart. So I'd take that side spring washer off too, put the nut back on and tighten another nut against it, lock xxxxxxg tight together, hold with a spanner on each and unscrew the rusty or stuck nut. In real life of course, you're only replacing them because they're knackered!
Top
 Profile
PostPosted: Thu Nov 09, 2017 5:36 pm
Offline
Peter, nice to know about the MS Shafts. I haven't tried them in a while but will revisit for sure. Did the lab do a Rc Test on the case?
For a while in Aust Production, they did fit them with a Nyloc Nut. They are a bit of a bugger to get undone, usually I remove the outer nut, fit a plain nut locked on the outer, undo the inner, then remove the out.
Top
 Profile
PostPosted: Thu Nov 09, 2017 6:37 pm
Offline
Hi Spider
It's the application of the force and not always the force required. ;)
Top
 Profile
Who is online
Users browsing this forum: 66Traveller, Metronick and 12 guests
Search for:
Jump to:
cron
