mk1-forum.net
It is currently Sat Jan 19, 2019 11:22 pm
Post new topic Reply to topic  [ 83 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9  Next
Author Message
PostPosted: Sat Dec 30, 2017 7:54 pm
Offline
And I've never heard of a single hose one before!
Supports my saying: The more I know about Minis, the more I know I don't know about Minis.
Top
 Profile
PostPosted: Sat Dec 30, 2017 8:46 pm
Offline
I agree Chuck.
I have 2 pumps here and both twin hose. You never stop learning.
Top
 Profile
PostPosted: Sun Dec 31, 2017 1:57 pm
Offline
iain1967s wrote:
minimk1man wrote:
I have emailed you a scanned image of the instruction plate on mine. Hope its OK for you.
Thanks Trevor, that's exactly what I needed. I should be able to use it to create artwork for engraving a new plate at one of the online services.
Update: PDF and MSWord file of my recreated placard attached, in case anyone else needs one.
Iain, just sent you a pm.
Top
 Profile
PostPosted: Thu Jan 04, 2018 2:24 pm
Offline
Found a cap that fits if anyone else needs one.
Jerry Can Cap for 1412 / 1415 - Blue 5001B ROYAL
eBay item number: 322444925319
Top
 Profile
PostPosted: Fri Jan 05, 2018 12:56 am
Offline
I wonder if Inpress Plastics was the original supplier of tanks?
Top
 Profile
PostPosted: Fri Jan 05, 2018 1:11 am
Offline
Something I discovered on my pump was the vacuum Schrader chuck is a Turner "Renrut" chuck off a Kismet foot pump.
Top
 Profile
PostPosted: Sun Jan 07, 2018 3:00 pm
Offline
Seamist Green 1100 wrote:
Sometghing I discovered on my pump was the vacuum Schrader chuck is a Turner "Renrut" chuck off a Kismet foot pump.
Yeah, I've been tracking a few of those on eBay. Trouble is the pumps are also collectors items so it gets expensive real quick...
A modern alternative is to use the couplers used for refilling nitrogen in aircraft landing gear struts. There are two designs available, one with a 1/8" male and one female. Both have separate Schrader thread clamps and screw-in pin depressors, which is the whole point of the original adaptors on both sides of the pump. Obviously if you have a single line pump you only need one of these - they aren't too cheap...
Note that the thread clamp on these strut couplers uses a copper washer to seal against the top of the Schrader stem, so it will need tightening down with a spanner to seal properly, not just finger tight as with the original coupler. I might try using a small O ring instead of the copper washer.
The male version plus a 1/4" to 1/8" reducer seems to fit well for the pressure side of the pump. Note: It feels like it will screw directly on to the thread of the bleed screw even though one side is NPT and the other is BSP, but if you want to do it properly use a thread converter.
I haven't tried it but I think the female version with a 1/8" NPT to a hose barb would be a good replacement for the renrut on the vacuum side, since that connects directly to the 5/16 ID hose rather than to a screw coupling.
Here is a photo with the assembled pressure side, this is just hand tightened using plumbing PTFE tape as I don't have the NPT to BSP thread converter yet - waiting for delivery. Amazon numbers for the parts I used so far are below.
For pressure side:
Stainless strut valve no-loss coupler 1/8" NPT male
https://www.amazon.com/gp/product/B005VR4M88
Brass 1/4" NPT female to 1/8" NPT female adapter
https://www.amazon.com/gp/product/B013RWMGAY
Brass 1/4" BSP female to 1/4" NPT male converter
https://www.amazon.com/gp/product/B015ROAYWC
For vacuum side:
Stainless strut valve no-loss coupler 1/8" NPT Female
https://www.amazon.com/gp/product/B00JJND6AK
Stainless 1/8" male to 5/16" ID barb (5pk)
https://www.amazon.com/gp/product/B017N4U13Q
Top
 Profile
PostPosted: Sun Jan 07, 2018 3:50 pm
Offline
Did you manage to get the instruction plate engraved then, looks new.
Top
 Profile
PostPosted: Sun Jan 07, 2018 3:54 pm
Offline
Can anyone tell me if the neck of their tank where the cap goes has thread all the way round, like a regular jerry can, or if it's just a couple of short lengths like mine? Thanks
Top
 Profile
PostPosted: Sun Jan 07, 2018 3:57 pm
Offline
No, I could not find anywhere to make a custom 3.75" x 9" size, so I just printed it on white card using a regular lazer printer then had it laminated in 30mil plastic at the local stationer.
Top
 Profile
Who is online
Users browsing this forum: minimk1man and 17 guests
Search for:
Jump to:
