mk1-forum.net
It is currently Mon Mar 25, 2019 3:18 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2, 3
Author Message
 Post subject: Re: 22G846 Gearbox ?
PostPosted: Fri Apr 13, 2018 3:04 pm
Offline
dodge44 wrote:
...Many seem to dismiss the 22G846 box as being just Elf / Hornet but as I'm sure you are aware Alan at least some of the examples fitted to early 1300cc ADO16's
Pulling on an old thread, but I've come across these remote gearboxes on two Mini's here in USA recently.
One is on my 1967 Mk1 S (not the original box, should be a 333), and the other is on a 1972 Austin Mini 1000 Super Deluxe which I think is original to the car. Note: Both have Mini style diff, not ADO16 sandwich plate.
I am curious for how different the 22G1128 and 22G846 gearboxes really are - for example are the internals common between both, with just 'cosmetic' variations such as ribs/strengtheners in the alloy casting itself?
It seems like both gearboxes were being used by BMC across their model range from 1967 onwards with several years of overlap, rather than rationalising to a single part.
Just wondering if there was any reasoning to that - for example was it BMC practice to allocate a different part number to differentiate first vs second source of casting suppliers? Could this be a marque thing - Cowley vs Longbridge? etc.
Top
 Profile
PostPosted: Fri Apr 13, 2018 7:31 pm
Offline
The 22G1128 and 22G846 gearboxes internals are common between both, both are 4 syncro.
If there are any differences between these two casings they are very subtle.
Top
 Profile
PostPosted: Fri Apr 13, 2018 8:19 pm
Offline
I bought one recently and refurbished it for an S engine I am building. It come with a ME laygear (close ratio) 4 synchro as other have suggested. I changed the diff and output shafts for the hardy spicer variants. Nice box.
Top
 Profile
PostPosted: Fri Apr 13, 2018 8:28 pm
Offline
I can't say with certainty here, however, I believe that the primary supplier of the Gearbox Castings were from Birmingham Aluminum Company and these were supplemented by castings from Stirling Metals Limited.
I'm just wondering if these may have been supplied by the latter and the more common cases from the former?
Top
 Profile
PostPosted: Tue Nov 06, 2018 12:19 pm
Offline
It would seem the 22G846 casing was also used for early Rod type boxes. In this case the box is fitted with the pre Pot type drive shaft couplings, the selector rod holes are not machined and something like the later Rod type rear is attached. No photo in the listing but presumably the bottom of the case is machined to take the Rod type gear change mechanism? Couple of pictures - there are more on ebay :-
https://www.ebay.co.uk/itm/Classic-Mini ... 6016.l4276
Top
 Profile
PostPosted: Tue Nov 06, 2018 8:23 pm
Offline
I bought an 846 box from Dave (spoon450) on the forum for my new Downton motor. It’s a cracking gearbox with mini remote change not ADO 16, definitely 4 synchro and really smooth.
_________________
1964 Downton Converted DPU 898B
Top
 Profile
Who is online
Users browsing this forum: aga2 and 19 guests
Search for:
Jump to:
